Audio System FAQ's
"Again using the stock Harley head unit as an example. The HU is a 2 ohm source. Then you went out and purchased two sets of 4 ohm speakers to replace the stock ones and fill the rear pods you picked up. To keep from possibly doing harm to your HU, specifically the internal amplifier, you are going to need to wire them in parallel."
Does that only apply to when you're trying to just use the HU, or would you have to do the same wiring set up with an amp as well?
Is the 2180 capable of running both the front and rear speakers? If it is, I assume I'm going to lose performance on both because the amp is doing "double duty"? With that set up would I have to go to the 4180 to get the full power out of the front and rears?
Now more specifically about your questions regarding the BT amp and speakers. First, since this equipment is designed by the same company it is meant to work together and compliment each other. That being said the 2180 is only a 2 channel amp. It is rated to be stable down to 2 ohms. The speakers are rated at 4 ohms. So you could wire the two 4 ohm speakers on each side in parallel. This would reduce the load to 2 ohms on each channel and the specs on BT's website for that amp show it will push 4 speakers when wired in parallel.
So, yes you could wire the four speakers to the BT2180. However I don't know if the HU's on the 2013's can be have the fade enabled. I would imagine it could be but if you're wired in parallel you won't have that option since both the front and rears on each side are connected to a single channel.
If you really wanted to be sure you were getting full performance out of all four speakers and the amp as you mentioned, I'd go with the 4180. One speaker per channel is always preferred and it gives you the opportunity to have the ability to fade if it's indeed an option available with a flash.
Think big picture, which it looks like for the most part you are. Based on the upgrades you've mentioned. If you're already planning on dropping the $$$ on 7.1's up front, 7.1's and the pods in the rear, and the amp. Now isn't the time to go all Scrooge on the purse strings for the sake of the $180 to go with the 4180 over the 2180..... unless you absolutely have to.
My question is, can I use my Polk speakers (which I currently have mounted in the fairing) in my lowers and wire them parallel with the BT 7.1 speakers I will be installing?
if so, what mounting hardware do I need to buy to install those speakers into the lowers?
thank you guys so much for all the guidance and support and helping me lighten my wallet.
