Wiring Soundstream PN.540
Old Feb 21, 2015 | 10:52 AM
Northbound Southerner's Avatar
Default Wiring Soundstream PN.540
I have a quick question. I have the need in the near future to wire six 4 Ohm Speakers. Two pair of 5.25 and One pair of 6.5s. Both are Polks. On the 5.25s, can I just go positive to positive and negative to negative to pair the right side speakers (this would be in a Woodys fairing where you have two pair on each side) and then run that straight to the output of that channel and be at 2ohms? I would repeat on the other side. Is it safe for the amp/speakers? If so, is there any reason I can't use the other two channels to run my 6.5 speakers in my lowers (they would be at 4 ohms...)? Is this the best way to do it? Forgive the possibly ignorant questions...I gave this stuff up over 20 years ago...
Old Feb 21, 2015 | 03:38 PM
Gannicus's Avatar
Gannicus
Yes. As long as your amp is 2 and 4 ohm compatible.
Old Feb 21, 2015 | 04:11 PM
It is the soundstream pn.540 so I think it is.
Old Feb 21, 2015 | 04:18 PM
Gannicus's Avatar
Gannicus
Yes Sir! I should have noticed that on the title. . .lol
Old Feb 21, 2015 | 04:23 PM
Do you think it will sound ok wired like that? Is there a better way?
Old Feb 21, 2015 | 04:32 PM
Gannicus's Avatar
Gannicus
I would wire the 6.5's on the front channel alone and wire the 4 5.25 speakers in parallel on the back channel. Should sound good with that amp.
Old Feb 21, 2015 | 04:38 PM
Sounds like we have the same plan. 6.5s on two channels and 5.25 on the other two
Old Feb 21, 2015 | 05:39 PM
Gannicus's Avatar
Gannicus
Yep! You're Golden!
bdjhog
Mar 21, 2015 12:30 AM
Fantozi
Audio Systems
42
Jun 27, 2014 12:53 PM
kevinm
Audio Systems
Apr 11, 2014 11:26 PM
arlinsg
Jun 4, 2012 06:57 PM
bandit5001
Mar 5, 2012 06:32 AM
