Pac swi-rc help
Old Mar 23, 2015 | 11:38 AM
JPMathers's Avatar
JPMathers
Default Pac swi-rc help
put pac swi-rc on this weekend programmed fine after about 10 min it lost vol+ memory checked again and wouldn't control any switches...reprogrammed 4/5 more times lost memory every time after about 10/15 min ...just wondered if anyone else had this problem...called tech support he said maybe the bike needs to be running while programing guess I'll give it another try after work...any help would be greatly appreciated
Old Mar 23, 2015 | 07:18 PM
HD_Doobie's Avatar
HD_Doobie
Do you have your battery tender plugged into the bike? Apparently that can throw off the programming..just a thought
Old Mar 23, 2015 | 09:34 PM
msr082881's Avatar
msr082881
6th Gear
Make sure that the handlebar control wire that goes to ground is tied to the ground wire as the radio is. Also not a bad idea to program it while it's running with all your lighting on. Hope this helps.
Chops@TxHD
Jun 30, 2015 04:41 PM
SDVmnt
Audio Systems
19
Mar 31, 2015 07:28 AM
skeetskeet
Audio Systems
Feb 25, 2014 08:11 PM
tmac00333
General Topics/Tech Tips
Oct 10, 2011 06:39 AM
milwaukeegeorge
Jun 2, 2010 09:01 AM
