Amp for Roadglide
Old Apr 12, 2015 | 09:44 AM
landlord6's Avatar
landlord6
5th Gear
Originally Posted by Gannicus
No problem with the 2 ohm stock radio. Once the unit is amped the amp controls the impedance to the speakers. You will need this harness for the rear speakers:
http://www.vtwinaudio.com/store/prod...ker-outputs-2/
This is for the HK radio, is it the same harness for the older radio. Hers has the 23 pin connector from the radio? I did not see anything on their site for the 2003. I was thinking I would solder some jumper wires into the wires and run a trailer plug to the rear so I can keep the tourpak detachable. I saw that suggestion in a different thread from UltraNutz.
Old Apr 12, 2015 | 12:41 PM
Gannicus's Avatar
Gannicus
Originally Posted by landlord6
Ok,speakers & amp came this week. I was reading the FAQ and it mentions the stock HU is 2ohm. Will this be a problem with wiring in the PBR300-2 amp. Also since her bike did not have the tour pack stock I need to run wire for the rear speakers, will this have to be done in series? I will search for a thread on wiring it but could use the help.
My bad I was under the impression you had upgraded the radio to an HK radio? The radios from 1988-2005 were Radio sound radio's for Harley Davidson. They were not 2 ohm radios. When you said you were reading the FAQ's and it stated 2 ohm I assumed you had an HK. The 2 ohm HK is from 2006 - up. Okay back to business. Anything you read form Ultranutz. . . Do it.
Old Apr 20, 2015 | 08:37 AM
landlord6's Avatar
landlord6
5th Gear
I have everything wired in, Power is wired direct to the battery with 10ga wire and a 30a fuse from an extra battery tender cord I had. I used the existing stock speaker wires for the input, then the output from the amp goes to the speakers. Used a trailer wiring plug for the tourpak so it is detachable and this is wired parallel. I used 1kHz test tone on cd to set the gain, from my calculation it should be 22 volts with this setup.
Is this the correct size fuse? It had a 7.5 a fuse in and I promptly blew that and put in a 30a but I don't want to burn anything up.
Sounds great BTW. I haven't taken it on the road yet because I wanted to get it dialed in before putting the fairing back on. Thanks for all the help.
Old Apr 20, 2015 | 09:22 AM
Gannicus's Avatar
Gannicus
If we are talking about the inline fuse for the power wire 30 amps should be fine for the PBR300X2. The fuse at the battery should always match or exceed the fuse rating of the amp. For example: if you have a sound stream amp with a 40 amp fuse your inline fuse to the battery should be 40 amps or higher.
Glennbowers8144
Audio Systems
Feb 12, 2017 09:31 PM
65049
Audio Systems
Nov 13, 2016 01:47 AM
Briguy1
Audio Systems
Aug 1, 2015 02:02 PM
toprat
Audio Systems
Dec 17, 2013 01:49 PM
Astro
Jun 21, 2012 04:29 AM
