Using the Metra ASWC-1 connector. A little nervous about this pink/white wire. Cut it and you want to go from the handle bars to the provided connector correct?
Doesn't matter but seems strange that is the only wore to splice and both sides of handle bar controls will work? This right?
You want to cut the pink/white wire on the side of the connector that goes to the handlebars (clutch side control harness) and attach it to a ground. You can use the cigarette lighter ground or the ground on the triple tree.
Thanks.
there is a STICKY in the audio section... handling all things related to ASWC-1... might want to read it and save yourself some time and frustration...
Ok, so I think I got. Before the plug, cut the wire. From the handle bar gets grounded and the other end (towards harness/bike) splice the ire from AWSC.... Right? GTG?
