FM Reception Problem
Old May 5, 2015 | 01:37 PM
simmer's Avatar
simmer
Default FM Reception Problem
Hey guys, need some suggestions....I have a Pioneer deck and put in the BT Amp and speakers (see sig). When I took out the HK Stock head unit and replaced it with the Pioneer I simply plugged the antenna into the antenna port but got no reception. Is there something I should know? Is it an interference thing with the amp?
Before the pioneer deck and amp install, I was getting great FM reception. Now I get absolutely NOTHING. Just static.
What should I do to troubleshoot this?
Old May 5, 2015 | 05:25 PM
big papa AZ's Avatar
big papa AZ
Do you need a antenna adapter for new HU??
Old May 6, 2015 | 02:44 PM
AAWAV's Avatar
AAWAV
Bt amp does not impact FM reception . Either pioneer hu or antenna is the issue.... open fairing, check antenna connector. If pioneer came with the famous yellow wire, hook it up to test. Wire will impact FM negatively but just test. Then go back to the stock sweep...
01Glide07HX
Audio Systems
May 1, 2019 07:47 AM
roussfam
Audio Systems
11
Jun 24, 2014 04:10 PM
Clwtr HD
Audio Systems
May 28, 2014 02:38 PM
FFZHD
Audio Systems
May 4, 2014 11:16 PM
Sparky73
Sep 10, 2013 01:45 PM
