Running 4 speakers.( fairing BT Titan II value brand, fairing lowers Kicker cs 65 series) What should the cross over setting be on. Hp, Lp, or F?
Thanks,
Brian
I would say F is the default for "Full Range" meaning all sounds comes through, none is blocked and all is amplified.
HP means High Pass, so it would allow the higher frequencies ONLY to pass to the speakers. Low pass is the exact opposite where only low frequencies pass through to the speakers.
Yes Sir! Papa nailed it. Flat with the speakers you have.
