Boom Audio windshield speaker replacement
Old Aug 28, 2015 | 12:33 PM
johnson27's Avatar
johnson27
Default Boom Audio windshield speaker replacement
I know, Boom audio windshield speakers aren't the best option for Road King audio, but, its what I have and its pretty convenient. Just finished a 1000+ mile trip, and, I just think the little 3.5" speakers could be 'tired'. Has anyone taken apart the windshield system and replaced the stock 3.5's?
I'm planning on switching to POLK AUDIO DB351's. Assuming they fit or I can make them fit, anyone have experience with these speakers? Or, better yet, swap out the speakers and have advice? The speaker has pretty good reviews.
Thanks, here is the set up I have mounted on the windshield
Old Aug 29, 2015 | 12:49 PM
pp6000v2's Avatar
pp6000v2
"There's no replacement for displacement."
3.5" speakers are limited by their small size. Upgrading the internal speakers may be possible- it's all going to hinge on the specs of the amplifier in the system. I don't know of any rated specs for the unit's amplification, but I don't expect it to be mind-blowing.
The Polks are 4-ohm speakers rated for 35W RMS power, while the Boom speakers may be 1,2,4, or even 8-ohm depending on what Harley designed the system around. Check the existing speakers for impedance before you buy anything. Assuming the speakers are an impedance match, what is the RMS power output of the internal amplifier? The Polks are rated at 105W Max, but again are only 35W RMS. Is the internal amp putting out more or less power?
More than likely, your best case scenario is going to be slightly cleaner sound, but not much more of it.
Old Aug 29, 2015 | 01:14 PM
Gannicus's Avatar
Gannicus
+1 agreed. Dead center fairings are nice on the road kings. Two speaker system with the 6.5 infinity's would be a night and day difference.
Old Aug 31, 2015 | 07:17 AM
johnson27's Avatar
johnson27
Default Thanks for your help guys
The amp with the system is advertised at 40W.
I might take the speaker enclosure apart and see if I can find any more info on the speakers. I don't necessarily need it louder, but a cleaner sound would be great.
I am looking at fairings, but, given the cost, I will most likely just hold out for a trade up to a Road Glide in a couple years.
Thanks
Old Mar 4, 2016 | 03:41 PM
PaddyH3GM's Avatar
PaddyH3GM
Default Any luck?
Any luck with this? I'm thinking the same thing. Need better sound as the bike gets up to speed.
Thanks
Old Mar 4, 2016 | 03:45 PM
johnson27's Avatar
johnson27
No, haven't messed with it yet. Should do it this weekend if it warms up.
it was 8 degrees this morning, forecast says 60 on Tuesday. Love Winter, NOT
fromydum
Jul 30, 2017 06:14 PM
el loco rico
Aug 13, 2015 10:31 PM
selandbe@gmail.com
May 15, 2014 09:30 PM
chgofirefighter
Audio Systems
Apr 12, 2014 10:45 PM
stbobfisher
Audio Systems
Aug 23, 2013 06:30 AM
