Kenwood and PBR 300x2 problem
Old Sep 24, 2015 | 06:27 AM
kblackmon's Avatar
kblackmon
Default Kenwood and PBR 300x2 problem
Hey guys I just recently upgraded the HU to a kenwood KDC-BT958HD, I am running 2 PBR 300x2. This unit has 3 rca outputs front, back and sub. I thought it would be a better sound quality using the RCAs. I'm also using hua360. I am not getting any input using the rca cables? Neither amp is turning on. So I used the speaker wires coming out of the HU and the amps work? I'm missing something? Thanks kevin
Old Sep 24, 2015 | 06:54 AM
haze324's Avatar
haze324
When u use RCA you need to connect a remote wire
Old Sep 24, 2015 | 07:31 AM
roussfam's Avatar
roussfam
By remote wire, are you talking about a 12v signal for turning on the amp?
Old Sep 24, 2015 | 07:41 AM
Gannicus's Avatar
Gannicus
Yes Sir... That's exactly what he's talking about.
Old Sep 24, 2015 | 09:09 AM
kblackmon's Avatar
kblackmon
thanks for the replies... I'm assuming it connects beside the power and ground terminals.. i have thrown away my instruction book for the amp.. thanks again kevin
Old Sep 24, 2015 | 11:48 AM
SBates08's Avatar
SBates08
Yessir that's where it connects. Use the amp remote wire from your head unit, it should be blue. Run wire to first amp, then a jumper from that amp to the second amp.
2010 Limited with some stuff
teedoff65
Audio Systems
17
Jul 20, 2019 11:27 PM
snarl16
Audio Systems
May 30, 2018 06:27 AM
KSGLIDEGUY
Audio Systems
36
Mar 1, 2018 12:52 PM
toddrick
Audio Systems
Apr 29, 2015 08:42 AM
NC_John
Feb 25, 2012 08:45 AM
