Is there an adapter for the output rca connectors or can they be cut off and speaker wire be spliced into the wires.
What are you using to feed the input of the amp? Your not trying to wire speaker level inputs into it are you? You should either be using a bt355 line leveler or a pac sni35 LOC between the speaker wires and the amp input
