Bike System
Old Oct 21, 2015 | 10:24 AM
duglaura&flhti's Avatar
duglaura&flhti
Originally Posted by Aero993
Kryingame,
That will occur in phase II along with a few other mods. Thanks
Looks damn good Aero. Well done using Bar/shield grills. Clean look and you painted cvo speakers pods. Nice. D.
Old Oct 21, 2015 | 12:38 PM
Gannicus's Avatar
Gannicus
Originally Posted by haze324
Aero....how did you wire this?
Be advised that if you wired these speakers in parallel you are running at 1ohm and the amp does not support that low of a load --- It will cook. I'd ask the local shop how they wired it, I'm hoping they wired it in series but that means you're not getting the full potential the amp can push or that the speakers can handle.
An easy option is to get a small amp in the bags and power the 5X7's. Even a small PPI 350.2 for 100 bucks would sound killer and more than double the output of your fairing and lowers. Here are some numbers:
At 2ohm to each speaker that amp pushes 220w.
At 4ohm it pushes 140.
You cannot wire 2 and 2 in parallel. You can do that with 4ohm speakers and that drops the total impedance to 2ohm and then you get 110w to each speaker. If you wire 2 ohm speakers in series the amp sees 4ohms or in this case 70w to each speaker. If you use a small second amp in your bags the speakers will get all 220w. Big difference between 220 and 70w. Your speakers will sound much better with the added headroom. That shop should've advised you of this.
Tweeters look great btw.
+1 A second small amp for the 5x7's would be a night and day difference. Obviously the shop has your system wired in series. Sounds good. But you would be amazed at the difference if you followed Haze's post. Night and day my friend. Those speakers literally scream with that amp if powered on their own channel. But if your happy with the sound. I'd leave it alone. Just sayin that's a killer system and it has so much more potential.
Old Oct 23, 2015 | 05:31 PM
duglaura&flhti
Originally Posted by kryingame
Man, get that inner fairing painted. Your scoot is beautiful and all a high gloss, except for that dull inner fairing. That was my first mod.
But congrats on your install.
PAINTED INNER FAIRING...Mine too after the tall boy handlebars installed. Looks so clean and custom. Get alot of comments for the inner fairing and skull gauges. Nice job.
WoodButcher66
Audio Systems
Feb 13, 2019 08:04 AM
chgofirefighter
Audio Systems
20
Jun 11, 2018 09:36 AM
fl1996nos
Audio Systems
22
Jul 15, 2015 09:23 PM
TO34
Audio Systems
Jul 12, 2015 07:11 PM
vtdiesel
May 17, 2013 09:47 PM
