Install questions ...
Old Oct 26, 2015 | 07:36 AM
UltraClassicWNY's Avatar
UltraClassicWNY
Default Install questions ...
I have just about everything installed and the PN4 1000D power and ground hooked up. I have a Sony MEX100 HU and a biketronics module/ install kit. I'm going to run the RCA cables, front and rear from the HU to the Amp. All 4 sets of speaker wires to the amp. As far as the Biketronics module for the handlebar controls, All that needs to be hooked up in order for it to work is the 3.5MM jack hooked up to the radio 3.5MM jack and of course, plugged into the bike harness?
Also, does anyone know how to remove the wires from the module, once the wires were pushed in?
Old Oct 26, 2015 | 08:31 AM
haze324's Avatar
haze324
For the module, you should have red, black and yellow plugged into it. If you need to remove them press in the white button/tab above the wire. They are spring loaded, pushing it will release the spring and allow you to pull the wire out. Same for putting it back in.
Also, don't forget you need a remote wire from the amp so that it turns on. You can connect a remote wire to the remote from the radio, or at the end of you headlight harness there is an orange and white wire that serves as a remote.
Old Oct 26, 2015 | 08:39 AM
UltraClassicWNY
Thanks again haze !
Old Oct 26, 2015 | 09:34 AM
jester0618's Avatar
jester0618
Stupid question, but I'm in a similar boat. I've got a 14, wiring in the same amp. The current amp, PBR300x2, doesn't need the remote wire hooked up to turn it on. Will the soundstream? The current wiring goes from deck to HD harness. I've tapped into the speaker wires in and out of amp. If I go RCA cables as OP did, will I need the remote wire?
Old Oct 26, 2015 | 09:45 AM
haze324's Avatar
haze324
Jester ---- yes you will need a remote wire. You can use your cig lighter. (see BT's install guide for details, pics).
I think V Twin sells a wiring harness that attaches to a plug above the radio.
Gunslingerglide
Audio Systems
18
Jun 16, 2017 06:50 AM
robert.schoelkopf@gmail.com
Audio Systems
Oct 30, 2015 10:21 AM
DeneFXDWG
Audio Systems
Apr 15, 2014 11:02 AM
ridedaddy
Audio Systems
Mar 17, 2014 02:39 PM
Bo Joe
Mar 30, 2013 10:35 PM
