How Install Cerwin B2 without cutting wires?
Old Nov 10, 2015 | 06:26 AM
rrcrum's Avatar
rrcrum
Default How Install Cerwin B2 without cutting wires?
How is the Cerwin Vega B2 being installed without cutting wires and not using a line converter such as magic box or biketronincs.
Ask since it only has RCA inputs into the amp and cutting the ends off them to hook to speakers looks as if it will leave some pretty fine wires.
Old Nov 10, 2015 | 06:35 AM
SBates08's Avatar
SBates08
Your gonna have to use a line converter to make it work. I suggest the one from Biketronics. No way around it on the Rushmore bikes.
2010 Limited with some stuff
Old Nov 10, 2015 | 11:22 AM
rrcrum's Avatar
rrcrum
SBates thanks for the reply, read so much kind of got the head spinning, guess what is confusing me is thought others are doing flash instead of line converter, or are they doing both. I seem to read converter, no converter, flash, no flash. And I working on a 16 Road glide.
Proposed setup is CV B2 (already purchased with recommendation from here), with Kappas. And if I go get flash, that is a whole new mystery to me as what is should be set as.
Currently have, PBR 2, with Magic Box, and Kappas. No wires cut and no flash, but not happy with output.
Old Nov 10, 2015 | 12:04 PM
SBates08's Avatar
SBates08
I think you'll be happier with the new line out from Biketronics. Leave the flash stuff alone, leave it at the stock flash. The updates won't hurt anything though, that's totally different. With the CV amp you should see a big improvement.
Old Nov 10, 2015 | 08:51 PM
rrcrum's Avatar
rrcrum
Thanks again Bates, figured after 109 views and only 1 willing to offer advice it must have been the right advise. Ordered the Biketronics line converter tonight.
Old Nov 10, 2015 | 09:04 PM
SBates08's Avatar
SBates08
Good deal. Hope you get the results your looking for.
KSGLIDEGUY
Audio Systems
36
Mar 1, 2018 12:52 PM
Jamie Benge
Audio Systems
15
Nov 22, 2015 12:12 PM
CHIPMOVER
Audio Systems
Apr 8, 2015 10:57 AM
2010blueultra
Audio Systems
Mar 11, 2015 06:14 AM
foundry guy
Audio Systems
Mar 24, 2013 09:16 AM
