Lost all treble to front speakers
I think it's a combination of all of the above.
Output Voltages on amp were for testing only
Using 1k hz test tone
At 60mph AVC OFF
14.2 volts battery
11 Volts output at amp
AVC 1 BAR
16 volts amp output
AVC 2 BARS
24 volts amp output
AVC 3 BARS
27 volts amp output
AVC 4 BARS
27 volts amp output
So with this said I have came to the conclusion I feel I have found the reason for the blown tweeters.
The AVC DOES INCREASE the output voltage considerably at 16 v ac in my test.
I have seen it posted to be careful using AVC with higher powered amps. This raises a couple of novices questions.
- When AVC kicks in I am assuming this increases the voltage which increases the current to the speakers? A little help from google...
- If the above is true and assuming we knew what the voltage increase was for each increase in AVC was, would there a way to compensate for the voltage/current increase when setting the gains by DMM?
I suspect this would take some high tech equipment and each combination of speakers/amp would be different.
- I am probably over thinking this but would like to know the best advise to give when recommending these high power amps. I think all the info is out there, but it scattered throughout forum. I have come up with a few recommendations/warnings when using HIGH POWER AMPS in particular. Please correct me if I am wrong. And if anything else should added to the list.
- Choose your components carefully. Always ask before making a purchase!
- When installing an after market amp on a 2014+ bike with the stock HU (head unit/radio) use the Biketronics Line Levelers. There is more info on the LL's here and another here.
- Settings gains is crucial. If setting the gains with a DMM (see procedure) then go to this post in that thread before calculating the AC voltage. Better to be safe than sorry!
- Make sure the bike is running and increase RPM's to achieve ~14.4 volts. If there is ANY doubt, ask!!!
- Once the gains are set correctly, be careful when increasing the AVC (Automatic Volume Control). This will add more power to the speakers the faster the bike is traveling! The best advise is to turn AVC OFF on the HU.
Were those truconnex still installed when you did this? It might be worth knowing to the other members if line levelers are part of the equation or not. I'm not sure how or if the gains on them would affect amp output as well.
Wonder if we can get Bill from BT to take a look here?
Voltages at the output side of the truconnects was 2.7 volts(at idle) with sled idling and no movement.
The AVC gets a signal from the BCM via the can bus.
I tried the test on the stand in 6th gear and 60 mph on speedo and voltage didn't change on the output of the amp.
I had to get out on the road to get the AVC to activate so it is getting input from the vss and another sensor
(I could not find the other input on the wiring diagram) so I am guessing it it from an ABS sensor on the front wheel.
The Demon is in me for about $300 so far but I will KICK HIS *** before I am done so for everyone else won't have to go thru this like I am
Rushmore test MONKEY I have become!!!!
