Need advice for a better system
Old Dec 14, 2015 | 08:35 PM
IzzoQuazzo's Avatar
IzzoQuazzo
Retired Admin
I have no dog in this fight. I have a Hogtunes setup and am very happy with it.
Old Dec 15, 2015 | 02:10 PM
draggingframe13's Avatar
draggingframe13
Originally Posted by Bertk
You may want to start by taking the fairing off and seeing what you have under there and let us know.
Is FM a must?
I may look into doing that. Yes FM is a must, as I listen to cds alot, I do like to have the radio accessible.
Old Dec 15, 2015 | 02:14 PM
draggingframe13
Originally Posted by SBates08
Dragginframe needs a 4 speaker setup guys. It's for an Ultra.
I'm thinking Kappas up front, Kickers in the rear pods, and several amps to choose from. SS pn4.520, SS pn4.1000 to name a few.
Thanks! Do you have a preference on which model kappas and kickers to go with and what amp would match up good with those? Would you recommend me switching out the head unit also? Thanks
Old Dec 15, 2015 | 03:09 PM
SBates08's Avatar
SBates08
Now your opening up a whole new can of worms. Absolutely recommend changing the HU. Here's the tricky part...you wish to retain FM. Before I make any suggestions I need to know what your budget is. Retaining FM makes things a little harder because you narrow down the amps available.
Old Dec 15, 2015 | 03:51 PM
09baggerdude's Avatar
09baggerdude
Default advertising within threads...
If the forum rules allow it, I get that. It will get old though, if every time he posts something, it turns into a sales event.
This has happened before on another forum I belonged to. "You can get that here" the "here" being a link to his site. Just hope that doesn't happen here cuz this is a GREAT forum with GREAT members! It can turn ugly in a hurry...I've seen it!
Just my $.02
Old Dec 15, 2015 | 04:07 PM
draggingframe13
Appreciate the help so far Bates! I just took the outer shell of the bike an hour ago and everything is tagged with HD part numbers, so I presume it's all stock. I guess I don't really NEED the FM radio, but it sure is nice... I wanna say my budget is to try n keep everything under 800$ max. I'd really like to stay around 500, but now that I've discovered changing out the HU, I guess I now have to raise my budget a little. And I'm not looking for anything to win audio competitions, I just wanna be able to turn it up louder than what stock gives me AND keep the clarity. Thanks again!
Old Dec 15, 2015 | 04:59 PM
Babyboy's Avatar
Babyboy
Default Need advice for a better system
I'll agree with SBATES
The SS PN 1000D
Infinity kappa 62.11i
Kicker ksc674 for the rear
This set up is about $350
It's a good setup sounds great. Just put the Kickers in the rear pods on my 14 limited they are a warm good sounding speaker and the Kappas scream with that amp
Old Dec 15, 2015 | 05:18 PM
SBates08's Avatar
SBates08
Originally Posted by Babyboy
I'll agree with SBATES The SS PN 1000D Infinity kappa 62.11i Kicker ksc674 for the rear This set up is about $350 It's a good setup sounds great. Just put the Kickers in the rear pods on my 14 limited they are a warm good sounding speaker and the Kappas scream with that amp
Add this Sony HU and these 6.5" mount rings and your good to go. This combo will get you a fine sounding system for under $600.
http://www.sonicelectronix.com/item_...MEX-M70BT.html
http://m.ebay.com/itm/SPEAKER-ADAPTE...-/121358701848
http://www.cartoys.com/kappa62-11i
Amazon.com : Kicker 41KSC674 6-3/4" 2-Way Coaxial Speaker - Pair (Black) : Electronics Amazon.com : Kicker 41KSC674 6-3/4" 2-Way Coaxial Speaker - Pair (Black) : Electronics
Amazon.com : Soundstream PN4.1000D 1000W 4-Channel Picasso Nano Series Class D Amplifier : Car Electronics Amazon.com : Soundstream PN4.1000D 1000W 4-Channel Picasso Nano Series Class D Amplifier : Car Electronics
Old Dec 15, 2015 | 05:21 PM
draggingframe13
The SS PN 1000D
Thanks BabyBoy! Just did some shopping on amazon and those 3 things you suggested came to 325 shipped! Now I just need to do some more research on what the pros and cons of replacing the head unit are...
Old Dec 15, 2015 | 05:26 PM
haze324's Avatar
haze324
You will also need:
5.25 to 6.5 adaptors
An amp install ki
and a roll of polyfill /polyester batting
It is likely that that amp will cause you to lose FM reception. With an aftermarket HU you have tons more options. Pandora, Sirius radio, stream from your phone, etc. It makes a HUGE difference in sound quality. You're looking at about 150.00 for radio, 40.00 for install kit and 100.00 for the hand control module.
That system is night and day over what you have now.
