For you guys who have gotten rid of your speaker pods in favor of the BT brackets I'm curious as to any other mods/additions you did for best performance from the speakers. I ordered a set of brackets from Bill and am curious if anyone has added polyfill or anything extra to maximize speaker performance
I'm curious what was the reasoning behind doing that?
I did it too.
Because I saw it on the internet.
__________________
NO, they DON'T all do that!
ROCKOUT rocker shaft inserts... make the tapping STOP! From the guy that FOUND and CURED the problem NO ONE ELSE COULD, thank you for your support! Ordering & info http://www.rockout.bizOn ebay! ...CLICK HERE Also on amazon.com...
The foam fills the 1/2" + empty air space between the BT speaker bracket and the fairing. In theory it keep the air flow moving forward and not leaking back into the fairing.
I have read others have used dynamat on the inside of the outer fairing. Maybe GANNICUS OR HAZE or one of the other resident guru's can chime in on this
