Amps and FM reception
Rockford Fosgate released the TM400X4 & TM400X2 (siliver marine version) with this update already in place, so all models have controlled EMI.
Rockford Fosgate published an EMI Installation Advisory describing the issue and installation tips to minimize issues when locating the amplifier and running cables in the fairing. I'm including a summary with a link below where you can download the actual PDF:
ISSUE:
Class-D and Class-A/D amplifiers have power supplies that switch on and off at high frequencies, which can emit EMI (Electro-Magnetic Interference) signals into the air. These signals can cause interference with signal processors, wireless devices, and radio waves including AM and FM signals. Modifications in amp designs have been made to keep this to a minimum. However, devices that are in close proximity to the amp can still suffer from such interference.
SOLUTION:
1. Mount the amplifier as far away as possible from the motorcyles radio, antenna and antenna cable.
NOTE: Antenna placement seems to be key. Bikes with a rear whip antenna seem to be O.K. Fairing mounted aftermarket antennas do not work when amplifier is mounted to radio.
2. Keep amplifier cables - which carry interfering signals - away from radio, antenna, and antenna cable.
3. Provide a good amplifier ground. Ground cable should run directly to battery. Grounding an amp to motorcycle fairings or forks is insufficient due to higher current requirements of amplifier.
4. Aftermarket tuners are more susceptible than factory tuners to noise issues. Amps mounted close to aftermarket radios have more interference than amps mounted to factory Harley-Davidson radios.
5. Some stations might get skipped by the SCAN function, but if manually tuned, will come in fine.
2014 & NEWER MODELS ONLY:
Image2014 factory Harley-Davidson radios have a Cat Scan - if not set up right - will not allow tuner scan to stop on all channels. A software reset may unselect previously chosen AM/FM search categories. To resolve, enter Cat menu and check each genre to include when scanning radio stations.
Read the original Installation Advisory here and download the PDF:
http://rftech.custhelp.com/app/answers/detail/a_id/1170
If that is the case, how can we differentiate the older units from the newer units with the chokes installed?
