BT2180 Installation Question
Old Jan 24, 2016 | 01:15 PM
WestTexasRanger's Avatar
WestTexasRanger
Default BT2180 Installation Question
I planned to install my BT2180 today, using a module spacer, so that the amps would sit on both the spacer and the CB Module.
But alas, I can't find the spacer that I took off my bike a few years ago.
Should I set the amp on top of the radio (left side in photo), on top of the CB module, or relocate the CB module under the radio and mount the amp to the middle of the radio.
I haven't installed a BT amp before and am trying to avoid any clearance problems, based you youz guyz's experience.
Thanks for the help and GO PATRIOTS!!!
Old Jan 24, 2016 | 02:18 PM
Gannicus's Avatar
Gannicus
Ranger -
You have to relocate the CB under the radio.
Old Jan 24, 2016 | 02:22 PM
WestTexasRanger
That's what I was thinking but wanted to be sure.
Thanks!
Old Jan 24, 2016 | 10:49 PM
WestTexasRanger
Originally Posted by Gannicus
Ranger -
What's the best way to mount it under the radio these days? I haven't been able to find a bracket/shelf/tray to do the job.
I wish that Biketronics offered something.
At one time I used the bracket built by Scott Ezzell but I read that he isn't making them any longer.
I've also used velcro & zip-ties to secure the module to the bottom of the factory radio but experienced premature CB failure, I'm guessing from vibration.
Old Jan 25, 2016 | 12:15 PM
Gannicus's Avatar
Gannicus
Yeah I had the Scott Ezzell bracket. But I remember after he stopped making them NUTZ knew of another place to get the bracket. I can't remember where it was from. Might want to PM NUTZ. If you can't get in contact with Nutz I'll do a search and try to find the thread.
Old Jan 29, 2016 | 10:18 AM
WestTexasRanger
I talked to Bill & Mike at Biketronics and they've never heard of a CB Module failure relating to relocation of the module. I guess mine was a fluke.
They'd actually built a few prototype shelves but feedback from their "test subjects" indicated that the velcro & zip-ties was more than sufficient and easier/quicker to install than the shelf.
Bill offered to sell me one of them, if I absolutely thought it was necessary, but talked me out of it. The module is now velcroed (3M Industrial) to the bottom of the HK head-unit with a zip-tie around it, the radio and the BT2180 sitting on top.
If you decide you need or want a bracket, give Bill a call. I'm sure he'd like to clear them out of his inventory.
Old Jan 29, 2016 | 12:05 PM
Gannicus's Avatar
Gannicus
Thanks Ranger!
Old Jan 29, 2016 | 02:04 PM
WestTexasRanger
I've used polyfill around the speakers in my previous installations. I found a super cheap J&M foam pad, so Im going to try it in my batwing.
Should I use the polyfill as well?
Old Jan 29, 2016 | 02:23 PM
Gannicus's Avatar
Gannicus
What speakers do you presently have?
Old Jan 29, 2016 | 02:31 PM
WestTexasRanger
Just put in a pair of BT 7.1s (standard)
