Outside the Box Again (SUB)
Old Feb 23, 2016 | 12:58 PM
sponger's Avatar
sponger
How does that st25 sound facing into the sides of the bike?
Old Feb 23, 2016 | 02:29 PM
Kesean's Avatar
Kesean
You can hear them clearly.
Old Feb 23, 2016 | 03:54 PM
LL247's Avatar
LL247
Former Sponsor
Originally Posted by Kesean
I really like the pro audio set up. Loud, crisp and clear and will most likely drown out anyone riding with you. I've done it a few times, LOL! Now I will say you do sacrifice the low end. You get more of a punch than bass response. If your genre of music is rock and country then its most ideal. If its jazz, r&b, or hip hop then you will need something a little extra for bass accommodations. Now I have heard a bike that had a mix. He used (4) 6x9's to give him the low end needed and sounded really nice with the Hertz SV165.1, ST35 and ST25. Wasn't sure on the amp(s) he was running.
I will post a video soon of my set up. As I said earlier I was on the fence about adding a sub but I'm glad I did. Those that have heard it are now inquiring about how they can get their sounds hooked up.
I'm actually in the opposite belief about the bass. I believe I have more since it's playing more audible frequencies in an open environment. At least to my ears it does. I hear more bass with DD 8s and lower wattage than I did with kicker comp 8s and 650 extra watts. Sounded ok until you started moving.
The reason I was asking though was more about your thoughts on the hertz setup. I'm pretty convinced I'm going to do a full replacement with Hertz, except for the 8's. I have a lot of people telling me the memphis mojo pro 8's put out some nice bass for pro-audio speakers. Now that I picked up memphis too, probably doing a pair of them in the bags.
One of my friends runs all DD and reps my shop pretty heavy. Our setups are similar and like to compete LOL. I'm afraid of pulling the DD for Hertz, and him beating me... Add to that my bike is my rolling business card, need to kill it this year.
Old Feb 23, 2016 | 04:09 PM
Kesean's Avatar
Kesean
Ahhh ok gotcha! You won't be disappointed in the Hertz trust me. If its loud, crisp and clear you want you will certainly get that. A lot of the shops doing builds for competition are using Hertz SPL's in their builds. Now I will agree on keeping the Mojo's as they do produce better bass response than the SV200.1. Which horns are you planning on going with ST 25, 35, or the 44?
Old Feb 23, 2016 | 04:52 PM
haze324's Avatar
haze324
I agree. It's the nature of what these speakers are designed to do and play. I don't care what brand they are DD, Hertz, Memphis, etc. these are mid-range drivers that are not designed to play sub level freqs, hell not even intended for mid bass frequencies either especially considering that in a saddlebag that is probably more cubic feet of airspace than recommended for an enclosure for mids to produce lower freqs. It's loud and it has that "punch" but it's not "bass" per se. My guess that's why Kesean is biting the bullet and trying out a 10 inch sub.
I compare PA speakers to going to a rock concert and good coaxials to top of the line surround sound system. One is louder the other is more musical. I think if you are going the PA route you have to understand it's not intended to be a Bose surround sound system. Some brands I've found to be warmer than others, some cleaner sounding, etc. and I've seen enclosures that bring out a warmer sound but for bass you need a sub. The baddest bikes I've heard have all be designed similar to a car - front stage (fairing) rear (bags) and subs (tour pack).
Old Feb 23, 2016 | 11:42 PM
LL247's Avatar
LL247
Former Sponsor
The direct replacement to my current custom install with the DDs will be the 35s in the glove box doors, and the 44s in the bag lids. Probably looking to add another set somewhere too, just not sure where.
Haze, I'll agree to disagree with you on the pro audio stuff...to a point. I wouldn't use the comparison, as my DD setup sounded every bit a clear and musical as my full Arc setup did. I will agree there a very fine crispness at the higher end that the horns can't really seem to capture the same.
Let me ask you cats this since you're audio crazy like me: What would your opinions be to run a full pro audio setup throwing a high end set of regular components in the mix? I was thinking now that I'm running lowers, to run sv's in the lowers, st35's and maybe a set of milles in the fairing. I would be running them off different amps of course. Then round off the bags with a set of sv's, st44's, and memphis mojo 8's. Honest opinions?
Old Feb 24, 2016 | 08:51 AM
haze324's Avatar
haze324
LL
It's not about disagreeing brother, this is based on specs and the physical design of PA speakers. When you raise sensitivity you give up the ability to play lower frequencies...just the way it is. See if you can find a local car audio shop with a legit real time analyzer and see where your bike graphs out....I'm certain it will be mostly mids, and not much under 100hz. Take the Hertz SV200 8 inch speakers, they have a max linear excursion of 4.5mm, that's simply not enough to play under 80hz at volume which is why Kesean said to hell with it, I'm installing a speaker that is designed to play that low.
Old Feb 24, 2016 | 09:59 AM
Kesean's Avatar
Kesean
Originally Posted by haze324
LL
Absolutely correct.
Old Feb 24, 2016 | 12:16 PM
Kesean's Avatar
Kesean
The 44's in the bags lids will be more than enough for the rear. Won't need the redundancy of the ST35's or 25's back there as well. Honestly I would actually place the 44's in the bags vs the lids. Could be too overbearing.
Old Feb 24, 2016 | 12:50 PM
LL247's Avatar
LL247
Former Sponsor
LL
No man! Wasn't disagreeing about the bass aspect! I'm full aware of the differences of PA speakers. I was referring to the analogy of the rock concert thing. I believe the PA speakers have as much of a quality musical sound as conventional speakers. After running many setups over the last few years I think a good PA setup can produce phenomenal sound on a motorcycle. The analogy made me think you're opinion is PA speakers are more spl than sql, that's what I disagreed with. It's all good though! We all like our own flavors and that's what helps the bike audio world evolve.
So guys, what do you think about throwing a set of Milles in the fairing and running the SV's in the lowers?
Kesean, I get what you're saying with the 44s in the lids. I'm already running the B2s there and they're not overbearing, guessing the 44s aren't going to put out THAT much more.
