6.5 component speaker system
Old Mar 6, 2016 | 05:38 PM
blainer's Avatar
blainer
Default 6.5 component speaker system
Is anyome running 6.5 component speakers in thier fairings? Seems like the speaker would clear the stock grills easier. Looking at some hertz components but unsure of what amp I should go with. Im thinking the hertz hpc2 amp would be great, any recommendations?
Old Mar 7, 2016 | 10:05 PM
Gannicus's Avatar
Gannicus
Component speakers are normally more power hungry than coaxial speakers. Therefore you need an amp with power to push em. The Hertz HCP2 is a weak amp at 65 watts@ 4 ohms. You would be severely disappointed with that amp. You would be much happier with a Biketronics 2180, A Cerwin Vega B52 or a Rockford Fosgate T400X2ad all with enough power to push your speakers.
Old Mar 7, 2016 | 10:51 PM
Iron 1250's Avatar
Iron 1250
I'm pleased to see this question Blainer and your answer Gannicus. I'm about to embark on an audio upgrade on a 2015 Ultra and the fairing is getting a pair of Hertz ESK 165.5's driven by a Soundstream PN4.320D bridged at 4 Ohms to deliver 160 watts a channel. Hertz claim a RMS of 100 watts and a peak of 300 watts so I'll be curious how they behave. I'll report once installed and tested.
Old Mar 11, 2016 | 04:34 AM
blainer's Avatar
blainer
I think ill go with the hertz hcp4d amp and a srt of hsk165 components. Im very disappointed with the stock speakers now that ive had more time to listen to them
Old Mar 11, 2016 | 01:32 PM
Gannicus's Avatar
Gannicus
Bro - I don't know how else I can say it. 65 watts x 4 is not enough power to push your speakers. The best amp Hertz has is the HDP4 @ 150 watts per channel @ 4 ohms. If you are hell bent on getting a Hertz amp. Get the HDP4. Best advice I can give you man.
Old Mar 11, 2016 | 02:18 PM
haze324's Avatar
haze324
are you going to bridge that amp to the HSK's?
Also is this for a pre-rushmore road glide. If it's for a streetglide you're going to have a tough time getting that into a fairing. You can, but it's not easy.
Old Mar 11, 2016 | 02:31 PM
Gannicus's Avatar
Gannicus
Even worse Bro. It's a class AB amp.
Old Mar 11, 2016 | 02:47 PM
haze324's Avatar
haze324
They also have a class D version HCP4"D".
I hope that's the one he's talking about!!!! LOL
Old Mar 11, 2016 | 06:51 PM
blainer's Avatar
blainer
Hi yes I am taking about the hcp4d, ts rated at 85watt pr channel but I figured bridged it would have plenty of power for those speakers? Im not stuck on hert, I just don'tknow where to source some of the other amps you mentioned.
Old Mar 12, 2016 | 01:38 PM
Gannicus's Avatar
Gannicus
Ahhh okay. My friend Haze correctly points out that is in fact a class D amp!! I stand corrected. Yes bridged that amp would supply enough power to drive your speakers. I don't think it will fit in the fairing though.
On the other hand if you wanted to expand your system in the future you would want a strong 4 channel amp at 4 ohms. So if you're going to purchase an amp that you will have to place in the saddle bags anyway. The best choice is the HDP4.
