Front speaker wires
Old Mar 11, 2016 | 05:46 PM
Cozz's Avatar
Cozz
Default Front speaker wires
Hello audiophiles. I just installed 6.5's in the dash. Are the black wire end terminals negative and the white positive? Just want to check with you guys before I go any farther. Not shown in the manual. Hmmmmmm must be a really dumb question.WTF
Old Mar 12, 2016 | 09:15 PM
09baggerdude's Avatar
09baggerdude
I'm not sure on your wiring, but here's a way to check polarity on your speaker. Take a battery (I use a double A). Hook a wire to each speaker post and to the +and- of the battery. If the speaker pushes out, your polarity is correct, if it sucks in, then it is backwards. If you use the speaker that was removed and know how it was connected, this will tell you which wire is what. Hope that makes sense.
Old Mar 13, 2016 | 07:20 AM
Cozz's Avatar
Cozz
Default Done
Got help on the touring board. Turns out , the wide blade black speaker terminal is the pos. Thanks though.
macabra11
Audio Systems
Sep 11, 2017 10:12 AM
Springerfan
Audio Systems
Jul 4, 2016 11:22 AM
sponger
Audio Systems
Mar 8, 2016 09:18 PM
TO34
Audio Systems
Jul 28, 2015 11:13 PM
coolerman69
Feb 27, 2011 10:01 PM
