Inner Fairing Brace
Old Mar 16, 2016 | 07:04 AM
-Joe-'s Avatar
-Joe-
Default Inner Fairing Brace
When I change my 5.25 speakers to 6.5 using the adapters, what do I do with the brace that mounts to the existing 5.25. I don't see how it can work with the adapters.
Old Mar 16, 2016 | 07:44 AM
Gannicus's Avatar
Gannicus
Nothing changes. The Bracket hooks to screw at approximately 7:00 o'clock on the speaker. What you have to do is loosen up both bolts and attach the side with the hook on it first. The bracket will appear to be in a bind but once you tack the other side down it will straighten out.
Old Mar 16, 2016 | 10:19 AM
-Joe-'s Avatar
-Joe-
Thanks. Looking at the back of the speaker, the brace is mounted in the bottom right hole of the speaker.it just didn't seem like the adapter ring would mount over it.
Old Mar 18, 2016 | 01:00 PM
azlou66's Avatar
azlou66
The adapter ring mounts under the brace. Install the adapter, then speaker, then brace.
Peculierboy
Audio Systems
Aug 21, 2014 10:34 AM
JerryK73
Audio Systems
May 2, 2014 09:02 AM
timeighty5
Audio Systems
Aug 29, 2013 11:12 PM
Ryder7140
Audio Systems
Jun 16, 2013 11:42 AM
tyrant33
Oct 12, 2007 09:45 PM
