Amp question
Old Apr 22, 2016 | 11:07 PM
fjimmy123's Avatar
fjimmy123
Default Amp question
what amp is suggested to push 2 HERTZ HCX 165 speakers for a 2012 street glide.. thank you
Old Apr 22, 2016 | 11:31 PM
slyedog's Avatar
slyedog
A good 150 watts will do it. I actually have a amp I just pulled with a custom mounting bracket and wiring ready to roll for it. It's a Image Dynamics MQ150.2. Amp is only 4 months old with just a few hours of time on it.
Old Apr 23, 2016 | 09:35 AM
floridapoolboy's Avatar
floridapoolboy
I use a Cerwin B2 with my Hertz hcx165s and it sounds great! The CV B52 will give you some more watts, should sound even better.
edit - Woohoo, 1000 posts!
Old Apr 23, 2016 | 05:04 PM
azlou66's Avatar
azlou66
I'm a huge fan of the CV B52 for a two speaker front stage.
Old Apr 23, 2016 | 08:12 PM
Gannicus's Avatar
Gannicus
Believe it or not if you bridge a soundstream 520.D to those speakers. They sound fantastic!! Just a thought!
Old Apr 24, 2016 | 01:47 PM
JM-ANDY's Avatar
JM-ANDY
Platinum Sponsor
Fjimmy123
One of THE MOST powerful 2 channel amplifiers available for your 2012 StreetGlide is here. http://www.jmcorp.com/ProductDetail.asp?ProductID=JAMP-330HC06
This amp is fully compatible with both 2 and 4-ohm speakers, has external adjustments to compensate for either and is 100% plug-n-play for ease of installation and keeping the full integrity of your motorcycle wiring harness.
If you decide to purchase, send email to audio@jmcorp.com for your HD-Forums VIP 20% disc code.
Old Apr 24, 2016 | 03:51 PM
Roadie13's Avatar
Roadie13
Originally Posted by JM-ANDY
Fjimmy123
One of THE MOST powerful 2 channel amplifiers available for your 2012 StreetGlide is here. http://www.jmcorp.com/ProductDetail....D=JAMP-330HC06
Curious if anyone can tell me if it's twice as good as the CV B52 or if anyone would even notice the difference between them both going down the road at 70 mph because per the JM website link the price is $550 which ends up being $440 with the 20% discount. The CV B52 is $180 on amazon. Just sayin...
Old Apr 24, 2016 | 03:53 PM
chadb72's Avatar
chadb72
Stage II
Hello I'm new here and having an issue looking for some help but cannot figure out how to start a thread could someone please explain thank you
Old Apr 24, 2016 | 04:31 PM
haze324's Avatar
haze324
Roadie good question. You know I've had some of the most expensive speakers and amps on my bike and honestly at some point the law of diminishing return kicks in. It's not a like 600.00 amp is twice as loud, clear, good, etc as a 300 amp. Sometimes they're better, sometimes they're not.
I think in this case the question by the OP was, what is a good amp for a set of Hertz HCX 165's. So with that being the focus, lucky for me is that I've had those speakers and have had them connected to a B52, Arc 600.4, BT 4180, PN4.1000D, Hertz HDP4, and the list goes on. I would say that Slyedog nailed it, the 150w mark for those speakers is on the money. Each of the amps I just listed made those speakers sing, in contrast I also had an Arc 125.2 and the 75w however "clean" they were, was not enough to hear those speakers at speeds. Being that the JM amp advertised above is rated at 165w at 2ohm, for some reason they don't publish the 4ohm specs (maybe I missed them) I would assume that amp puts out less than 100w at 4ohm? If so, I'd recommend going with something with more juice behind it like the Cerwin B52 or the amp Sly is selling that is a the same amp as the B52 at it's core with some upgrades to the internal components.
Old Apr 24, 2016 | 04:54 PM
Roadie13's Avatar
Roadie13
Great input Haze. Guys like you and Gann and the others that have tried every combination under the sun add some truly valuable feedback to this forum and it is greatly appreciated.
