Audio speakers and Amps
Old Apr 25, 2016 | 05:31 PM
zxport123's Avatar
zxport123
Default Audio speakers and Amps
What are some good amps that I can use to power four Infinity Kappa speakers, the speakers would be in the fairing and also the fairing lowers, also would I be able to add more speakers in the future and if so what type 2 ohm or 4 ohm.
Old Apr 25, 2016 | 05:47 PM
Budda109's Avatar
Budda109
I think you want a 4 channel amp. Whats your budget I am learning a lot about this stuff there two guys on here that have a lot of posts helping people. There is plug and play which costs a bit more, and there are a large range of watts going up adds cost. I have a http://www.sonicelectronix.com/item_...RZ4-2000D.html.
106 dollars. Love it 4 speakers lots of sound working on my tuner upgrade now.
Look for post from Haze324 and Gannicus. There plenty of people to help but these two really helped me with the choices I had. Good luck!!
Old Apr 25, 2016 | 06:11 PM
SBates08's Avatar
SBates08
If you start out with the Kappas, the only way to expand later would be to add another amp because the Kappas are 2ohm. I went that same route on my second upgrade. As far as amps go the Soundstream pn4.1000 will make those Kappas dance. Also a good amp for future upgrades should you decide to change speakers later on.
Old Apr 25, 2016 | 06:22 PM
zxport123's Avatar
zxport123
Thanks Guys!
Quickrunner1
Audio Systems
16
Apr 26, 2019 08:19 PM
CrBear
Audio Systems
May 27, 2017 08:22 AM
hdng
Audio Systems
Mar 10, 2016 01:06 PM
JHC210
Jul 22, 2015 10:28 PM
Just-Jeff
Mar 27, 2014 10:28 PM
