Issues with stereo. Questions
Old Jul 3, 2016 | 02:29 PM
Bertk's Avatar
Bertk
Originally Posted by Budda109
Thanks. FYI. The protection light is NOT on. The green light is bright and glowing. Ohms on speakers across coil are spot on. It is as if the amp has nothing to pass on to the speakers.
Looks like you have it narrowed down. Curious as to why the headlight is touching the harness. I the headlight stock?
With the fairing off can you provide a couple of pics including the back of the HU?
Old Jul 3, 2016 | 04:31 PM
Budda109's Avatar
Budda109
Don't have pictures at this time. But the headlight is not stock. It is the Phase 7 truck lite. Seems deeper. Also wires at the harness where cut short to hookup to amp. That made it a bit bulky.The headlight lines up with the back of the stereo. I am looking for anything that may be a cause. Since the only thing that may change is pressure on wires. Well that's a guess. Thanks
Old Jul 3, 2016 | 08:02 PM
Bertk's Avatar
Bertk
With the fairing off you could put some pressure on the area in question to try to repo it. You will also want to open up the harness and start inspecting each connection. Who knows what the previous installer did.
Old Jul 27, 2016 | 05:54 PM
Budda109's Avatar
Budda109
Default Wiring
A little feed back. When I checked his wiring found the wires frayed where the amp screw holds them down. So I soldered them to make a solid connection. I have some before and after pics. I also did mine. I had no trouble but I don't want any either. Thanks for all the help.
Attached Thumbnails Issues with stereo. Questions-wires1.jpg   Issues with stereo. Questions-wires2.jpg
Old Jul 27, 2016 | 07:05 PM
Bertk's Avatar
Bertk
Thanks for the feedback. Tinning the wires is a very good practice.
Putting a tiny amount of blue Loctite on the very top threads of the hold down screws will help prevent them from backing out also.
Jonny Rotten
General Topics/Tech Tips
Apr 12, 2019 12:49 PM
reddog#1
Electrical/Lighting/Alarm
Oct 16, 2014 07:22 PM
Jetjunkie
Oct 22, 2013 12:52 PM
Rauzer
Aug 11, 2012 05:15 AM
jeff.georgalas
Aug 26, 2010 07:09 PM
