Rushmore tuning sequence when using amp and BT Line Levelers
Old Jun 28, 2016 | 08:32 PM
rrcrum's Avatar
rrcrum
Default Rushmore tuning sequence when using amp and BT Line Levelers
Just read the whole BT Line Leveler sticky to not avail for my brain, although it came close once but then started mentioning Scopes, I have no scopes.
Can any one please list the best sequence to set up gains, like did you set amp gains first or LL gains first or LL frequencies first. on old bike I used the up 3/4 method then back off but only had the amp to contend with
Most concerned in the sequence of steps tune, not sure if I should mess with amp gains first of Line Levelers first.
Did you keep Full pass on or go to HPF,
My equiqment
Stock Head Unit
Cewin Vega B2
Kappa's
Old Jun 28, 2016 | 08:59 PM
InthewindMN's Avatar
InthewindMN
Biketronics claims that no adjustment is suggested on their line leveler so you would just set the amp gains and frequency. On that note, I tweeked my leveler a little to warm up the sound to my liking but it also adds some distortion so it's a double edged sword....
Old Jun 28, 2016 | 09:03 PM
Tailwind's Avatar
Tailwind
I would recommend leaving the LLs in the default settings and doing the 3/4 ear tune using the amp gains.
I am using full pass but certain that others will chime in on that selection.
T.
Old Jun 28, 2016 | 09:18 PM
rrcrum's Avatar
rrcrum
I pretty much feel the same way just below distortion on amp setting and when I start tweeking LL all seems to go out the window, and now that I have tweeked my leveler not really sure if I am even back to default settings, the only thing I can find on the biketronics site is a PDF picture of the Line levelers to help get back to default settings but no sequence to dial these things in, while using a tunable amp.
Old Jun 28, 2016 | 09:38 PM
haze324's Avatar
haze324
Their intended for use with an amp that has no gain settings.
I would leave the LL alone and just set the gains on the amp using the sticky posted. Grab a DMM and set the VAC with the bike running according to the chart Slyedog posted. If you have some distortion at full pass, then set it to HPF and raise the frequency cut off.
Old Jun 29, 2016 | 11:51 AM
rrcrum's Avatar
rrcrum
The reason I ditched the Magic box and bought the Biktronics Adjustable Line Levelers was the rave on here for the adjust ability function these. Now 3 suggestions in a row to leave them at factory settings???
Old Jun 29, 2016 | 07:25 PM
Tailwind's Avatar
Tailwind
My cave man explanation.
I think u might have misunderstood the purpose of the LL for the Rushmore as it takes the shixxy signal from the HU and performs some fancy internal magic. No need to adjust the gains on it as you have gains on your amp.
In a nutshell, your amp is getting much better input from the LL due to internal programming regardless of what u do with the gains. If u want to crank up the gains on the LL have at it, but a gain is a gain is a gain. Just use the amp if u need to increase the output.
T
Old Jun 29, 2016 | 08:31 PM
rrcrum's Avatar
rrcrum
Tailwind,
Thanks for the explanation in the simplest terms, that's what I need to understand sometimes, that helped as I was all caught up in tuning the LL.
Old Jun 29, 2016 | 09:36 PM
Tailwind's Avatar
Tailwind
Tailwind,
I have the BT4180 installed with no gain controls and also an amp with all the *****. On the BT the LL gain is my only way to increase amp output. On the other amp, it really just simplifies things to stick with the default of 12 o'clock for LL gains and LL HPF set at the lines, and use the controls on the amp. End result whichever gain u use or if its a combo of both gains is that you are targeting an optimum VAC / clean signal coming out of the amp.
Haze or some of these smart guys can explain technically what the LL does but essentially my audio pea brain understands that it levels out a really shixxy bass band / curve that is coming out of the Rush HU that is in place as a factory setting to make the Boom produce the least crappy sound possible.
The Rushmore guys have had amazing success with the LLs so hope u find the same.
Ultimately you are absolutely on point regarding your expectation of what us Rush guys really do need, and that is an equalizer that we can install to really gain more control of the HU output. It's on several of our list of audio goals so keep the faith!!!! Hope to break the code ASAP!!!!
T.
IndyNick
Audio Systems
Jun 20, 2018 01:11 PM
cfave
Audio Systems
Mar 1, 2018 01:06 PM
dub976
Audio Systems
May 22, 2016 08:49 PM
Angelsbass
Audio Systems
45
Mar 31, 2016 10:46 AM
Robjr
Touring Parts
Mar 13, 2016 01:33 PM
