Diamond audio 800.4
Old Jul 27, 2016 | 03:50 PM
Bertk's Avatar
Bertk
Originally Posted by Babyboy
I might possibly work with the JM amp mount but like BERTK said it will be tight
When Scott14SG installed the 1000D with the J&M mount he said it was tight. Adding a 1/2" to the width I would suggest having a plan B.
Old Jul 27, 2016 | 04:08 PM
Babyboy's Avatar
Babyboy
The SS PN4 1000D measurements
10.2 X 4.75 X 1.5
Compared to the 800.4
9.75 X 5.25 X 1.75
I was able to get the 1000d under the fairing using a stock amp bracket with a little modification for the length.Looking at the 2 different amp mount brackets I would have to say it would fit using the JM bracket but don't hold me to my work as I have not tried this yet.
Old Jul 27, 2016 | 05:44 PM
slyedog's Avatar
slyedog
10.2 X 4.75 X 1.5
9.75 X 5.25 X 1.75
With full front mounted connections I would not see many issues. Comparing to the Soundstream isn't quite as applicable as the Soundstream has all side connections. Tight fit still for sure but is doable with gauge notched on 13 down. 14+ supposed to fit with no mods. If velcro, zip ties, or any other half assed method of mounting is needed count me out.
Old Jul 28, 2016 | 12:18 PM
09baggerdude's Avatar
09baggerdude
Originally Posted by slyedog
You missed that there is also a 800.2. That wasn't Facebook advertised. That is 300x2@4 ohms. The 4 channel only has a advantage using it bridged to me. More headroom. Still likely a tight fit but plenty doable. I'll keep my arc for now till more feedback says otherwise.
The 4v2 is 300x2 @4 ohm mono...just don't see much advantage for the $$ difference. JMO
Old Jul 28, 2016 | 01:59 PM
slyedog's Avatar
slyedog
Cost are supposed to be near the same. Benefit of the 2 channel is better SQ running stereo vs bridged mono. Some notice the difference and some don't.
Old Jul 28, 2016 | 03:45 PM
09baggerdude
On a bike? Even at 40 mph...?
Parking lot? Maybe...Guess it depends on where it's playing. Front, rear, bags? 120 X4 beats the hell outta 80x4. But then again, it's not 150 X4 either.
Old Jul 28, 2016 | 04:47 PM
slyedog's Avatar
slyedog
The concept is mainly efficiency with a 2 channel vs a 4 channel running bridged. At 80 is it noticeable? As you said depends on speaker location but also headroom, speaker itself, etc. It's a Audiophile thing really. Less demand on amp usually results in better sound quality. Yes the new Diamond is a huge plus over the 4V2 in the 4 ohm stereo dept. Not 150 but still as you said 120 is 50% more than 80. I'm not planning on ditching my Arc for one yet. With the Arc fan cooled and being so efficient anyway I have never had mine even get neat hot. Thats running a solid test on a dummy load where it is near smoking and the Arc was still cool to the touch, where my tm400x2ad was damn hot.
tigerking
Audio Systems
17
Apr 1, 2018 10:01 PM
HogPilot54
Audio Systems
15
Jul 15, 2017 03:31 PM
Tailwind
Audio Systems
Jun 28, 2017 09:44 PM
djblackjack
Apr 24, 2017 04:25 AM
NHBAGGER
Audio Systems
Sep 10, 2015 03:43 AM
