tweeter suggestion
Old Aug 1, 2016 | 08:07 PM
no1_3fan's Avatar
no1_3fan
Default tweeter suggestion
Any suggestion which tweeters I should use with this setup. I am wanting tweeters to replace my gauges. I am getting ready to install a Kenwood HU, BT 4180 amp and BT 7.1 [non pro] speakers
Old Aug 1, 2016 | 09:02 PM
nineball's Avatar
nineball
unless you have some weird fascination with high frequencies there really is no need. i have the same speakers and they do just fine as they are. i actually had to dial the higher end frequencies down via my eq.
Old Aug 1, 2016 | 11:32 PM
Tailwind's Avatar
Tailwind
Yeah bro, those speaks are fairly damn bright already. If anything u should be thinking about adding complimentary warmth at a different location.
U will regret adding tweets!!!
Get some lowers or lids or TP pods with very good warmth and u will be in a much better place than more highs.
T.
Old Aug 2, 2016 | 06:14 AM
no1_3fan's Avatar
no1_3fan
Ok thanks, I will not do the tweeters. I have pods, any suggestions for a good speaker for pods ? I thought of putting 6.5 or the BT 7.1 back there
Old Aug 2, 2016 | 07:01 AM
nemick's Avatar
nemick
FWIW, I recently installed a pair of the BT 6.5 speakers in my fairing and ended up disconnecting the previously installed Hogtunes Tweeter Pod as it was all too bright for me.
Old Aug 2, 2016 | 09:17 AM
Gannicus's Avatar
Gannicus
If you have the stock pods. Throw the Polk MM651's back there. I have not found a speaker that sounds better back there with the stock pods. They drop right in and sound amazing in that location.
Quickrunner1
Audio Systems
16
Apr 26, 2019 08:19 PM
Kawickrice
Audio Systems
29
Jul 16, 2017 04:57 PM
Mcarso1
Audio Systems
May 8, 2015 03:17 PM
chgofirefighter
Audio Systems
Apr 12, 2014 10:45 PM
jjpish
Audio Systems
Apr 11, 2014 08:02 PM
