I will try using the kenwood amp for rest of this season and then go with a better one next year. Could you explain how to wire the 4 speakers in series please? Thank you
As SB is saying, your running a 4 channel amp, you don't have to worry about wiring in Parallel or Series.
Thank you very much to everyone that has helped me! What would be the recommendations for a replacement amplifier that I could start looking for an install over the winter? Thank you again :-)
To completely dumb this down, your 4 channel amp has 4 outputs, both with a + and - or positive (+) and negative (-). Your speakers also have the same set up. Simply run speaker wire to each speaker and be sure to keep polarity (+or-) correct. Hope this helps and we all started in your shoes. Please report back with anything that you might find helpful to others.
Kris
Kris
Kris
Can't dumb it down too much for me! Haha! Thank you
