Amp speaker question
Old Sep 29, 2016 | 08:51 AM
  #31
yooperhog's Avatar
yooperhog
Originally Posted by BrysZ
I am a little confused the infinity kappa 62.11i are rated at 75 watts RMS however you all have been stating I should supply at least 125 watts per speaker. The Kenwood KAC-M3004 is rated at 75 watts also. I am sure its my ignorance showing again lol
http://www.infinityspeakers.com/spea...PA+62.11I.html
http://www.kenwood.com/usa/car/marine/kac-m3004/
http://soundstream.com/product/pn4-1000d/
the kappas are rated very conservatively at 75w RMS. your current amp maxd out will deliver your minimum. there will be no comparison between that amp and a sspn4.1000
I had kappas in front and hogtunes in tourpak pods. hogtunes rated at 125w rms. gains set equally on front and rear speakers. fried hogtunes and kappas still running strong. trust us on this, kappas will handle 150w all day long, maybe more
Old Sep 30, 2016 | 08:08 AM
  #32
BrysZ's Avatar
BrysZ
Last question (i doubt it lol)...if I were to upgrade the headunit what should i look for that would be at a reasonable price?
Thank you!!
Old Sep 30, 2016 | 08:34 AM
  #33
yooperhog's Avatar
yooperhog
Thank you!!
kenwood 998
sony mex70bt
alpine 149
probly the most popular for sound quality and tuneability with built in equalizer. they require an adapter kit for mounting and a wiring adapter for handlebar controls.
the aquatic av models are direct plug and play replacements for stock units. much better than stock hu, but wont give you the tuneability of the others
it all comes down to what u want
forum sponsors such as badazzbikes or 77customs can set u up with complete setup with the car options or the aquatic av
Old Sep 30, 2016 | 08:58 AM
  #34
BrysZ's Avatar
BrysZ
Originally Posted by yooperhog
kenwood 998
sony mex70bt
alpine 149
where do I find these adapters?
Old Sep 30, 2016 | 09:12 AM
  #35
yooperhog's Avatar
yooperhog
search amazon. get an idea what your lookin for. order from a forum sponsor to make sure u get the right set-up
Old Sep 30, 2016 | 08:50 PM
  #36
Bertk's Avatar
Bertk
Thank you!!
Here are a few feathers to look for:
A display that you can see while out riding. None of them are great but some are better than others.
At least one USB plug. I only one, it should be in front of the HU.
At least 3v preout
For tuning a Multi band EQ. Crossover controls, front & rear if possible. This will allow you to adjust the crossovers without taking the fairing off.
Just to name a few.
Old Oct 1, 2016 | 04:00 AM
  #37
Gannicus's Avatar
Gannicus
Your cheapest most effective option for an adapter is going to be the Metra set up which comes in two parts. First you will have to purchase this piece to hold your radio in place:
https://www.amazon.com/Metra-99-9600.../dp/B00JKXSM7G
In Addition you will have to purchase this piece to control your radio from the handlebars.
http://www.crutchfield.com/S-ZsLQaCv...l-Adapter.html
Both pieces come with a wiring harness but you will use the wiring harness from the Metra 99-9600 to wire your radio. This radio install kit will cost you anywhere from $70 to 80 bucks.
Your other two options for a radio kit is the Biketronics Kit which retains AVC:
http://www.biketronics.com/bt1005x-1...o-install-kit/
or the Hawg Wired Kit:
http://hawg-wired.com/product_info.p...th/51/pPath/96
Old Oct 1, 2016 | 06:50 AM
  #38
yooperhog's Avatar
yooperhog
Great post Gann. can you throw in a couple suggestions for a good splash cover too?
Old Oct 1, 2016 | 12:16 PM
  #39
Gannicus's Avatar
Gannicus
Sure Yooper! This one works great and is the most cost effective
https://www.amazon.com/Biketronics-S.../dp/B0031BQRVG
I prefer this one but it's much more expensive:
http://www.vtwinaudio.com/store/prod...f-radio-cover/
Old Oct 1, 2016 | 02:01 PM
  #40
Keith4001r's Avatar
Keith4001r
A wealth of info in this thread! Subscribed.
OP- PM sent.
BrysZ
Audio Systems
Oct 27, 2015 09:28 AM
kevinm
Audio Systems
Apr 11, 2014 11:26 PM
drugar
Audio Systems
May 13, 2013 07:48 PM
Brancajd
Jun 28, 2012 09:04 PM
bking
May 10, 2012 09:29 AM
