Hertz Components Comparison
Old Oct 15, 2016 | 07:46 AM
Gnarl78's Avatar
Gnarl78
I have a pair of Mille Pro's in my fairing and like them. They have a well-rounded sound - good mid-range and bass; not too bright. Loudness is okay to me. I think it depends on what amp you power them from and what your setup is. Mine are powered by a RF T400x2ad and they are my primary speakers.
Old Oct 17, 2016 | 08:29 AM
wideglide100's Avatar
wideglide100
Amp is still undecided, although 95% certain it will be the Moto 600.4 due to adjustability. I would also consider bridging this amp to the MLK 165.3 if you thought they need the extra power. Then figure how to stuff an additional NVX MVPA4 bridged to power the existing Polk MM651's in the tour pak pods. Oh, I guess I should have mentioned this is a Rushmore Street Glide. My goal is to maximize a 4 speaker set up with all amps in the fairing.
Old Oct 17, 2016 | 08:51 AM
haze324's Avatar
haze324
FYI --- you can't bridge one if those amps to a set of polks. Most class d amps are 4ohm stable when bridged. Those speakers are 2.7.
Old Oct 17, 2016 | 10:37 AM
wideglide100
So for this scenario I'd have to swap the rear tour pak pod speakers with a 4 ohm set.
That being said would you recommend staying all hertz and using HCX 165 or MPX 165.5
or go with the moto 602 considering any of these options will require spacers?
Old Oct 17, 2016 | 10:41 AM
BaddAzzBikes's Avatar
BaddAzzBikes
Former Sponsor
Either of those would be a good choice but you could also go with EVF 165s as a replacement. Shallow mount 6.5 in speaker that doesn't require a spacer.
Hoyt 1911A1
Audio Systems
Sep 29, 2018 04:08 PM
Keithholly
Audio Systems
Jan 24, 2018 06:36 AM
Jukebox
Audio Systems
16
Apr 3, 2015 07:13 AM
just plain john
Audio Systems
Sep 20, 2014 05:33 AM
Varooom
Jan 23, 2008 12:54 PM
