advice needed
Old Nov 12, 2016 | 07:08 PM
kmealp's Avatar
kmealp
Default advice needed
Ok i'm going to buy the aquatic av h/u, it states power 4x45w(4ohms)/4x72w(2ohms), amplifier class a/b (2ohms). I would like to run the kappa 62.11i speakers they are 2 ohms. My question is will the 2 ohm speakers be fine? thanks
Old Nov 12, 2016 | 08:02 PM
SBates08's Avatar
SBates08
The speakers will be fine. However, your spending a **** ton of money for a HU and speakers for minimal results without adding an amp.
Old Nov 12, 2016 | 08:33 PM
Ndfastln's Avatar
Ndfastln
Yes, the speaks will be fine with that, although they will be hungry for more power. You may need an additional amp to hear them well at speed.
Old Nov 12, 2016 | 08:51 PM
kmealp's Avatar
kmealp
I'm going to get the one with the built in 288w amp and if its not enough I'll add on. My buddy has it on his roadglide and loves it without a amp. thanks but if I do need an amp what would be a good one? Its going in my 12 ultra and want it to mount in fairing, and keep fm.
Old Nov 13, 2016 | 07:25 AM
Gannicus's Avatar
Gannicus
Gonna definitely need an amp!! Take a look at any of the Arc, Biketronics or Rockford amps to maintain FM.
Old Nov 13, 2016 | 07:47 AM
yooperhog's Avatar
yooperhog
had great luck with fm with aquatic hu and cerwin vega amp
Old Nov 13, 2016 | 07:55 AM
Gannicus's Avatar
Gannicus
Lol... even better!! The Cerwin Vega amps are cheaper!!
Old Nov 13, 2016 | 08:37 AM
yooperhog's Avatar
yooperhog
sounds pretty good with the kappas too.. was recommended by a great guy on this forum!!
Old Nov 13, 2016 | 09:05 AM
jimfreeman's Avatar
jimfreeman
I have that unit in my 2011 ultra along with the biketronics amp. I'm sure there are better combinations that cost less & sound better but for plug & play this works great.
Delgado130
Audio Systems
Mar 11, 2019 07:46 PM
blainer
Audio Systems
Mar 12, 2016 08:45 PM
TO34
Audio Systems
Jul 12, 2015 07:11 PM
lowglidin
Audio Systems
Dec 26, 2014 04:21 PM
jeff.georgalas
May 9, 2010 07:36 AM
