Biketronics double din
Old Feb 21, 2017 | 04:51 PM
  #81
tesnevo's Avatar
tesnevo
Originally Posted by matt76cmich
Would you have to use an RTA mic and pink noise to do that?
You can but truthfully your better off starting out the TWK in advanced mode, eq set to standard eq and adjust until it's fairly close. Then you can change the eq to parametric and go stupid crazy with it.
It's got a little bit of a learning curve but if you get it, same for you Sarge, let me know. I will get you guys through the first parts then turn you loose on your "NEXT" audio adventure, lol....
i would still highly recommend the Navone LOC's. They truly are phenomenal little units.
Old Feb 21, 2017 | 04:54 PM
  #82
matt76cmich's Avatar
matt76cmich
It's tempting Tes, but I'm gonna wait and see what my temporary FiX sounds like after i get everything powered up and go from there with my BAL guidance.
Old Feb 21, 2017 | 04:55 PM
  #83
tesnevo's Avatar
tesnevo
Originally Posted by Bunker
Tes, you using FiX's and TwK's or just TwK's? I thought you needed the FiX to flatten the signal then the TwK to do all your processing.
Just the TWK. Didn't see the sense in using a FIX unit to feed it. The two Navone LOC's are about 40.00 shipped vs $300.00 over the counter for the FIX.
If someone has the FIX unit and wants the TWK it's a simple rca out to in on the TWK, no LOC's needed.
Edited to add, I will start another thread on the TWK. Sorry OP don't want to trash another ones thread.
Old Mar 5, 2017 | 01:30 PM
  #84
Ozbernie's Avatar
Ozbernie
Where are Biketronics at with this head unit upgrade kit? Still not listed on their website.
Old Mar 5, 2017 | 02:04 PM
  #85
slyedog's Avatar
slyedog
I see them floating around on the web. They likely have to fulfil there pre order fully, then get stock on hand before they list them. Makes sense ina business perspective.
Old Mar 5, 2017 | 02:42 PM
  #86
Ozbernie's Avatar
Ozbernie
Sounds reasonable. Looking forward to when they stock it routinely. I will strongly consider purchasing at that time.
laman22
Audio Systems
29
Apr 18, 2019 09:41 PM
uwiik
Audio Systems
Aug 28, 2018 07:52 PM
slyedog
Audio Systems
Mar 26, 2017 03:17 AM
Bunker
Jul 26, 2016 02:17 PM
slyedog
Audio Systems
27
Jun 24, 2016 10:31 AM
