Dynamat Batwing Install - Rushmore
Old May 6, 2017 | 08:41 PM
  #91
Tailwind's Avatar
Tailwind
Originally Posted by HogPilot54
I just ditched my pods and installed the BT brackets. Now wondering about this Dynamat mod. For those who have done it, did you notice a big improvement in sound or just a little? I'm contemplating doing this mod but just doesn't seem like it would do a lot to improve the sound coming from the front speakers. Am I wrong?
Dynamat will make a difference with no pods. The other thing to make sure u do to stabilize the inner fairing is to add 1/4 20 bolts from the bracket to the inert fairing if u have not done so.
T.
Old May 6, 2017 | 09:23 PM
  #92
User 11821's Avatar
User 11821
T.
Can you elaborate on the bolts to the inner fairing or even better if you have some pics please post those here. I definitely have a LOT of vibration on my inner fairing that I don't believe existed when the factory pods were still installed. Thanks! Of course if there's already a thread discussing this, if you could point us in that direction that would be cool as well.
Old May 6, 2017 | 10:50 PM
  #93
Tailwind's Avatar
Tailwind
Yeah, I think there are a few threads with pics available so I will try and get u a link.
In a nutshell there are unused inner fairing bolt holes right on the top of the inner fairing just outside the fuel and volt gauges. These were the upper inner pod bolt holes. Grab a sharpie and eyeball and mark a drill hole thru the BT bracket. Get some 1/4 20 bolts about 1". Also in the fancy drawers at Home Depot there are white plastic bushings that house the 1/4 20s and these bushings are about 3/4" to full the gap between the inner fairing and the BT Bracket. U will have to file or bench grind just a 1/16 off the bushing to get a snug fit.
Drill hole in BT Bracket, hold bushing in place w vice grip or needle nose, insert bolt w lock tight, tighten, done. It takes 10 mins and makes a world of difference!!!!
Hope this helps!!!
T.
Old May 6, 2017 | 11:49 PM
  #94
User 11821's Avatar
User 11821
Hope this helps!!!
T.
Perfect. Now I do recall seeing unused mounting points when I was installing the BT brackets. A couple fasteners should make a tremendous difference. Now I have something to accomplish on my Sunday morning! Thanks.
Old May 7, 2017 | 08:41 AM
  #95
SBates08's Avatar
SBates08
I don't have the link but this is where the extra bolt and bushing goes.
Dynamat Batwing Install - Rushmore-photo958.jpgDynamat Batwing Install - Rushmore-photo91.jpg
Old May 8, 2017 | 06:41 PM
  #96
HogPilot54's Avatar
HogPilot54
Thanks for that info!! ^^^^^^^^^^^^^ My gauges did seem to vibrate more after I installed the BT brackets but I thought maybe I just never noticed this vibration before. Turns out I need to add these bolts and bushing! How come BT doesn't address this issue and include the bolts and bushings, along with drilling the extra holes in their brackets?
Old May 8, 2017 | 06:56 PM
  #97
Tailwind's Avatar
Tailwind
Totally agree brotha!!! Shoot BT a quick message and maybe if enough of us chime in, the will possibly address this for those that follow.
T.
Old May 8, 2017 | 07:00 PM
  #98
User 11821's Avatar
User 11821
I second that! I even called BT after I installed the brackets and said hey my **** is vibrating like crazy after installing your brackets. The guy in tech support (who, btw seemed bothered that I would even call) said nope we've never had anyone say that. We'll file your support call. This was only after he made me send numerous photos. Thanks for posting this. Simple yet effective overlooked step that BT could have done for the meager price charged
Old May 8, 2017 | 08:50 PM
  #99
HogPilot54's Avatar
HogPilot54
Isn't BikeTronics on this forum?
Old May 10, 2017 | 01:10 AM
  #100
mstrty's Avatar
mstrty
Originally Posted by fightingmajor
Are the stencils too big to just outline on a regular sheet of paper so that you could just host the files and let people download and cut out? Just curious and thought it might make it easier for people to grab.
When I had the stencils, I scanned them onto 8.5" x 11" pages. Print these out. You will have to tape together the larger pieces. Red registration marks are there to help you line up the pieces. Once taped together, just cut the outline. Transfer the paper stencils to dynamat. Nothing to ship. All you need is scissors, tape, paper and an internet connection.
Stencil is HERE
Enjoy!
