6.5" midrange/lowers guinea pig
PRV Audio 6MB200-4 6-1/2" Midbass Woofer 4 Ohm spec:
Product Specifications
Nominal Diameter6-1/2"
Power Handling (RMS)100 Watts
Power Handling (max)200 Watts
Impedance 4 ohms
Frequency Response 125 to 4,500 Hz
Sensitivity 93 dB 2.83V/1m
Voice Coil Diameter1.5"
Orion CM64:
Speaker Specifications
Priced Per Pair
Speaker Size 6-1/2"
Design Midrange (Midwoofer)
Woofer Composition Paper
Woofer Surround Cloth
Peak Power Handling 600 watts
RMS Power Handling 300 watts
Sensitivity 96.5 dB/w/m
Frequency response: 120 - 10KHz
Impedance (Per Voice Coil) 4 ohms
Top-Mount Depth 2.75"
Speaker Grilles Yes
On a side note, I was asked if I could wait till late April as Orion is releasing a new model to replace the CM64, a CM65. Same physical specs but a 180/360w power rating, 98dB sensitivity rating and a 120-12,000 Hz freq range. MSRP still will be < $100. Just some FYI...
https://www.sonicelectronix.com/item...rion-CM64.html
Sensitivity 96.5 dB
Frequency response: 120 - 10,000 Hz
Whereas the Pioneers at 124 are 92 db and 29-40000.
DD are 91 db and 40-25000
Congrats on becoming a guinea pig.
