speaker/amp upgrade
Old Feb 24, 2017 | 05:26 PM
Gannicus's Avatar
Gannicus
Originally Posted by jjlw
If I decide to add speakers to the lowers or tour pack will this amp work?
Yes Sir!!
Old Feb 24, 2017 | 05:27 PM
Gannicus's Avatar
Gannicus
Originally Posted by slhanks4
Does this amp kill your FM reception?
What Bike?
Old Feb 25, 2017 | 02:32 PM
jjlw's Avatar
jjlw
I think I've made a decision.
Infinity Kappa 62.11I 6.5" 6-3/4" 2-Way Coaxial Car Speakers 6-1/2" Harley 2 Ohm, fairing and tour pack.
Soundstream PN4.1000D 1000W 4-Channel Picasso Nano Series Class D Amplifier.
Metra 82-9601 6-1/2" to 6-3/4" Speaker Adapter for 1998-2013 Harley Davidson Touring Models.
BOSS Audio KIT2 8 Gauge Amplifier Installation Kit
8 Gauge, High Performance, AmpInstallation Kit with RCA and Speaker Wire.
30 ft of Speaker Wire
20 ft. 8 GA Red Power Cable, 16 ft. 18 GA Blue Turn-On Wire, 3 ft. 8 GA Black Ground Cable
Competition Quality Fuse Holder with AGU Fuse Plus #10, 5/16" and 1/4" Ring Terminals
6 ft. Split Loom Tubing, (3) Rubber Grommets and (20) 4" Wire Ties
A few more questions before I fully commit.
1. Boss amp install kit was recommended with the soundstream amp on Amazon. Is this a good install kit?
2. What other wiring will I need?
3. Will I need another set of adapter rings for the tourpack?
4. Will this amp completely kill my FM reception?
5. How will the amp mount on top of my stock head unit?
6. Anything else I'm missing?
Any other suggestions on speakers and amps welcome.
Thanks for all the answered questions and input.
Old Feb 25, 2017 | 05:47 PM
Gannicus's Avatar
Gannicus
1. Yes. It's decent. But there's better wire out there. I run NVX.
https://www.sonicelectronix.com/item...X-XWS1650.html
https://www.sonicelectronix.com/item...3QcaAiGU8P8HAQ
2. If you keep the stock head unit. You will need two PAC SNI-35 line levelers.
3.You will need 1/2 in adapter rings to mount the Kappa's in the rear pods
4. Not completely. You will get some stations.
5.Mounted on top of the HU with industrial velcro from home depot and cable ties.
6. Speaker wire needs to be 16 gauge and you will need a set of 1'.5" stinger rca cables for the amp.
Old Mar 6, 2017 | 05:09 PM
slhanks4's Avatar
slhanks4
Originally Posted by Gannicus
What Bike?
2011 Ultra Limited
Old Mar 6, 2017 | 09:09 PM
Gannicus's Avatar
Gannicus
2011 Ultra Limited
Yes Sir! If you want to keep FM reception. You're looking at the Biketronics, Arc, and Rockford fosgate amps.
Old Mar 14, 2017 | 02:03 PM
muhammed ibrahim's Avatar
muhammed ibrahim
Stage I
if you're looking for rockford fosgate amps check these post it is reviewing the best rockford fosgate amps
Old Mar 15, 2017 | 10:34 AM
Gannicus's Avatar
Gannicus
None of those amps will fit inside the fairing of a Harley Davidson Motorcycle except the PBR300X4 and I wouldn't say it was one of Rockford's BEST?
commander112
Audio Systems
Oct 28, 2017 09:04 AM
jcain
Audio Systems
Feb 28, 2014 07:58 PM
Astro
Jun 21, 2012 04:29 AM
Sincecrazy
Dec 11, 2008 06:55 AM
dchoran
Apr 28, 2008 07:01 PM
