Amplifier mounting road glide
Old Feb 27, 2017 | 04:49 PM
617south's Avatar
617south
Default Amplifier mounting road glide
Looking on suggestions for a bracket or mounting idea for the JL audio amp ?
Attached Thumbnails Amplifier mounting road glide-b975ecf5-eb75-435d-9032-306111b5fbb4.jpg
Old Feb 27, 2017 | 08:21 PM
mkguitar's Avatar
mkguitar
I've used these for a number of applications- use the existing holes for screws, and or drill what you need. robust, yet easy to bend to 90ş using a vice as a brake.
3" x 7"
you can use 1 wide ways using both radio screws,
or go 2 lengthways each using a radio screw with a third used to tie them together at the back.
cost $1.17 each
http://www.homedepot.com/p/Simpson-S...TP37/100375215
I'm cheep- this appeals to me., I hope that the metal helps as heat sink and as RF shielding. easy to run another ground wire.
some guys use 3M duolock which is like velcro for gorillas- I use this alot at work- the adhesive can be affected by heat and moisture...good for mocking up and temp installs. I often find that the adhesive pulls apart before the 2 pieces of duolock pull apart.
Mike
Old Feb 28, 2017 | 12:01 PM
CVOJOE's Avatar
CVOJOE
3" x 7"
cost $1.17 each
Mike
That's a good idea
FPV
Audio Systems
28
Sep 22, 2023 08:32 AM
DRBUICK
Audio Systems
May 31, 2018 06:35 PM
Mr D
2014-2024 Touring Models
Apr 30, 2015 12:58 PM
Wagney
Nov 17, 2014 03:53 AM
kjkustoms
Oct 31, 2012 06:43 PM
