antenna
Old Mar 2, 2017 | 03:24 PM
70ss's Avatar
70ss
Default antenna
Looking for the shortest antenna possible for tour pak any help would be appreciated.
Old Mar 2, 2017 | 03:36 PM
SBates08's Avatar
SBates08
Do you listen to FM?
Old Mar 2, 2017 | 03:52 PM
70ss's Avatar
70ss
sometimes
Old Mar 3, 2017 | 06:21 AM
UltraNutZ's Avatar
UltraNutZ
if you listen to FM, then why don't you take the antenna off the tourpak and relocate it either inside the fairing (laid across the top) or inside the rear fender support. Then just plug the hole or screw on one of the stubby worthless antennae
Old Mar 4, 2017 | 08:44 AM
billablehours's Avatar
billablehours
Just relocate the existing whip antenna for the best free reception. The reception is not quite as good as the antenna sticking up but better than the fairing mount or stubby ones in my experience. Here are a couple of YouTube videos. The longer one is how I did mine because I wanted it more secure. The shorter video looks like the guy didn't reuse the bracket.
I also just ran the antenna along the left side frame tube and tied it down with zip ties rather than under the tank mount. It is cleaner. Good luck
Old Mar 4, 2017 | 09:53 AM
squirrelsnest's Avatar
squirrelsnest
Walmart sells a flexible short antenna in the auto department that might work for you.
Old Aug 1, 2017 | 09:20 AM
hardheaded's Avatar
hardheaded
i have the short HD antenna and it seems to work just fine.
Greg Di
2014-2024 Touring Models
20
Sep 25, 2017 08:46 PM
Billf
Nov 5, 2012 09:41 PM
SharkBite
Feb 6, 2012 11:50 PM
army_sarge
Mar 13, 2010 08:29 PM
lightu
Aug 16, 2006 09:45 PM
