Steering wheel controls !!help!!
Old Mar 8, 2017 | 09:44 PM
NastyNate84's Avatar
NastyNate84
6th Gear
Default Steering wheel controls !!help!!
I have a new kenwood headunit. With a axxess aswc-1 control. Problem is I can get it to pick up on my volume down command!! It will pick up all the other controls. 07 street glide and it all worked before the swap. Any ideas???
Old Mar 8, 2017 | 09:52 PM
billablehours's Avatar
billablehours
Steering wheel? That may be your problem.
I think you may have posted in the wrong forum.
Sorry. Couldn't help it.
Old Mar 8, 2017 | 10:01 PM
NastyNate84
6th Gear
No harm lol I just went with the product name. As that might be the piece that is failing me. Not sure why the down volume is the only thing not working.
Old Mar 8, 2017 | 11:12 PM
SBates08's Avatar
SBates08
Where did you ground the pink/white wire? Find a better known ground and that should fix your problem.
Old Mar 9, 2017 | 06:45 AM
NastyNate84
6th Gear
I grounded it at the back of the cigarette plug.
Old Mar 9, 2017 | 06:57 AM
UltraNutZ's Avatar
UltraNutZ
are you sure you grounded the correct end of it? the end coming from the handlebar controls is the end you need to ground.
Old Mar 9, 2017 | 07:18 AM
NastyNate84
6th Gear
Yeah I'm pretty sure. But I'll double check. Funny that all the controls work but volume down.
Old Mar 9, 2017 | 07:19 AM
UltraNutZ's Avatar
UltraNutZ
did you pull apart your handlebar controls at all?
Old Mar 9, 2017 | 08:13 AM
NastyNate84
6th Gear
No I didn't. And I just tried a ground right to the battery and no luck with the volume down.
Old Mar 9, 2017 | 09:06 AM
SBates08's Avatar
SBates08
If your running an amp ground it on the ground post of the amp. I had the same issues with mine till I grounded it at the amp. Problem solved.
