Fix radio or replace
Old Apr 25, 2017 | 07:28 PM
Johnnypop's Avatar
Johnnypop
Default Fix radio or replace
My radio on the 2010 limited has a cd stuck in it. I called iron cross and was told not fixable without sending in. So I still hoping to get the cd removed or I will need to upgrade. I would like a plug and play system. I started looking around and now am confused. Life was simple when everything works
Old Apr 25, 2017 | 07:46 PM
slyedog's Avatar
slyedog
Replace it. The chance for long term usage before another failure isn't worth the cost Iron Cross will charge vs just getting a Aquatic or aftermarket cd player with a interface module. Not knowing the remainder of the system I assume it is all stock.
Old Apr 25, 2017 | 08:13 PM
Fireball Jack's Avatar
Fireball Jack
easy to pick up a used one that a member is selling. Aftermarket with an install kit is about 300.00
Old Apr 26, 2017 | 12:44 AM
JimTJr's Avatar
JimTJr
Iron cross makes them better than new though, I believe they go through the whole unit and tweek it,,, heard great things about them...
Old Apr 26, 2017 | 02:24 AM
gusotto's Avatar
gusotto
I'd go with Iron Cross repair.
They tweek the radio with upgrades.
Might lose the intercom feature with after-market radios.
Old Apr 26, 2017 | 03:54 AM
Gannicus's Avatar
Gannicus
These are your plug and play replacement options:
http://www.aquaticav.com/product-cat...idson-stereos/
As you can see the high end can get a little expensive. definitely cheaper with Iron cross but as Slye stated the stock radio will continue to have issues and eventually fail. for my money I would go aftermarket and call it good.
Old Apr 26, 2017 | 11:12 AM
duglaura&flhti's Avatar
duglaura&flhti
What G-man said....Better off in the end.
Old Apr 28, 2017 | 12:39 PM
Johnnypop's Avatar
Johnnypop
I found a used unit that will installing. Will a hogtunes front speakers improve sound or is the stock system is good as it gets without lots more investment
rg567
Mar 25, 2024 10:46 AM
BMARSC
Apr 21, 2018 10:28 PM
DBLX
Feb 24, 2017 07:39 AM
Perry Weaver
Nov 15, 2015 08:49 PM
HDV-GLIDE
Aug 3, 2011 10:47 PM
