Using sub pre out for full range output
Old Apr 26, 2017 | 07:15 PM
pglider's Avatar
pglider
Default Using sub pre out for full range output
Tried an experiment,used sub pre out of Alpine bt-149 HU for front channel on pn41000d set flat to the Moto 602 in lowers,sounds as if its getting a full range output from amp to the 602s,is that possible? Reason I tried this so I would not have to y the front ch from the mhx 280 bridged. Rear ch on 1000d is going to my lids,6900 pros.This radio is 4v pre out,just hate to split the pre out voltage,it does sound good but might need a processor instead,a little winded sorry.Thanks Paul
Old Apr 26, 2017 | 07:17 PM
slyedog's Avatar
slyedog
Some not all head unit will allow a full range signal from sub pre out. Splitters will not reduce the pre out voltage by anything more than .2 volts or so. Not even noticeable.
Old Apr 26, 2017 | 07:31 PM
pglider's Avatar
pglider
Thanks Slye I even adjusted the sub level on the Alpine to about 7 out of 15,Rode the bike, it didn't sound bad at all.Had a bad y adaptor that's why I tried it.Well I will get more y adaptors the week. [Stinger this time] .2 volts being split shouldn't affect output then.Wouldnt mind having a Hertz hdp4 BUT wont fit in my 08 batwing.Thanks again Paul
marcodarq
Audio Systems
19
Dec 8, 2018 03:37 PM
DAVENRINO
Audio Systems
Apr 5, 2018 12:35 PM
Cheesehead_13
Audio Systems
21
Dec 24, 2017 11:06 AM
Makdaddy
Audio Systems
13
Jul 24, 2017 04:50 PM
Gliden
Nov 18, 2012 08:22 PM
