Can a single amp push 6 speakers?
Old May 12, 2017 | 10:38 AM
Quickrunner1's Avatar
Quickrunner1
Default Can a single amp push 6 speakers?
Okay I want my cake and eat it too, that said... Is there an affordable amp that will fit in fairing on my 05 RoadGlide and push 6 speakers? Can a single amp even do that or are 2 amps required for a 6 speaker setup? I am replacing my stock head unit with the Sony MEXM70BT and would like to eliminate the small 2 speaker hogtunes amp/speaker setup and ditch the PBR300x4 but retain my 4 Polk speakers and add 2 more polks to replace the hogtune ones. Also are there adaptors to run 6.5 speakers in the factory location? the hogtune ones are oval shaped.
Old May 12, 2017 | 10:46 AM
BaggerAudioLab's Avatar
BaggerAudioLab
Yes --- but not those speakers. You would need 4ohm speakers to do it correctly and wire two sets "in parallel". Techincally you could do it with the Polks and wire them "in series" but you would cut your power by half. Not advised brother!
Old May 12, 2017 | 11:01 AM
Quickrunner1
The Polks I have are the DB series, I have two 6.5's cut into inner fairing down by forks and two 5.25's in bag lids. I think these DB's are 4 ohm.
Old May 12, 2017 | 08:15 PM
Gannicus's Avatar
Gannicus
Holy Cow bro!! What are you doing with 5.25 speakers in the lids? Get those things out of there and throw some 6x9's in there!! LOL!!
Old May 12, 2017 | 08:43 PM
yank721's Avatar
yank721
Yeah ditch those tiny speaks lol, you'll be blown away with 6x9's lol
Old May 12, 2017 | 09:41 PM
sponger's Avatar
sponger
Mmats 6150.d??????
Old May 13, 2017 | 06:20 AM
yooperhog's Avatar
yooperhog
am curious what type of lids you have that mount 2 speakers 5.25"?
Old May 13, 2017 | 11:25 AM
matt76cmich's Avatar
matt76cmich
Originally Posted by sponger
Mmats 6150.d??????
This might be over kill for his setup, but would definitely work mounted in a bag. The $1000-1200 price tag is another issue, but from what I've read it's a pretty impressive amp. Read where an all MMats setup with this amp hit 133db on a term lab mic.
Old May 15, 2017 | 07:39 AM
Quickrunner1
The Polk 5 1/4 are cut right into the front of lids and grills painted to match, I know it sounds rigged but it don't look bad. They are marine rated and been working for years like that. I know 6x9's would blow them away but at the time didn't have $ for new lids.
Old May 15, 2017 | 07:49 AM
Quickrunner1
You can see the lid speakers in this pic
