Kappa Mounting
Old May 29, 2017 | 08:57 AM
PostalRoadKing's Avatar
PostalRoadKing
Default Kappa Mounting
Do Kappas just "drop" into the fairing of a 14 Limited or do I need to plan on modifying the mounts/grills?
Old May 29, 2017 | 09:02 AM
ROCKOUT Rocker Products
Sponsor
Lots of more experienced guys here to help, but in my experience...
If you mount them outside the pods they will rub at the edges until they self destruct. Inside the pods you have some dremeling to do on the support ribs of the pods. Easy job.
They do sound good once in.
For ROCKOUT information & purchasing please click the LINKS below... For all Twin Cams and Evo Big Twins & Sporsters
__________________
NO, they DON'T all do that!
Also on amazon.com...
Old May 30, 2017 | 11:57 AM
daveblank's Avatar
daveblank
^^^^^ This. The pods come apart pretty easy, install them in there.
Old Jun 9, 2017 | 09:55 PM
PostalRoadKing
Going to try this tomorrow, any words of advice? I'll see tomorrow what you mean by a bit of dremel work.
Old Jun 10, 2017 | 03:42 AM
Gannicus's Avatar
Gannicus
This will help
Old Jun 10, 2017 | 01:00 PM
SprungDave's Avatar
SprungDave
The speaker grill is the major problem in your situation. Changing the stock ones to the H-D Boom or other aftermarket grill(s) will move the parts that would/could contact the speaker away from them.
You can also modify your speaker pods, as shown in the video, and it is free. Also, removing the lip of the pods where the speaker mounts can also allow the speaker to be moved further away from the inner fairing. This is also a free option.
Choosing a speaker that has a flat, thinner basket mounting ring, and a tweeter that does not protrude from the face of the speaker makes it so much easier, in general, to mount the speakers onto the face of the pods. Which is the easiest way to go.
Ride Safe!
Old Jun 10, 2017 | 11:14 PM
PostalRoadKing
Thanks for the input. Mounted the Kappas inside the mount, just had to cut off the standoffs then the speakers fit inside the pods. Didn't have time to tune the amp, will do that tomorrow, already sounds much clearer than stock.
NugBa
Jul 7, 2019 08:54 AM
Road Star
Milwaukee Eight (M8)
Jul 15, 2018 09:29 PM
reno55
Audio Systems
25
Jul 27, 2017 02:38 PM
KnuckleHD
Audio Systems
Nov 25, 2016 01:44 PM
q
Jan 12, 2007 04:28 PM
