Does a Ground Loop Isolator work?
Old Jul 3, 2018 | 01:28 PM
Budda109's Avatar
Budda109
Headwinds - 8-9030RS - Radio Static Filter? Before you order it. Unplug the headlight. Play the radio see if the static/noise goes away. I think you are going to have to try and remove one thing at a time to find it. Mostly because you did not do the work and have no history with the bike. Look for any type of ballast or load equalizer. Check all grounds. You can also get noise from having the positive and negative flipped on the speakers. Good luck.
Old Jul 3, 2018 | 03:13 PM
Hoyt 1911A1's Avatar
Hoyt 1911A1
it will help, but I've found some also filter out low end frequencies.
For some of us working with tiny little 6.5" speakers that ain't a bad thing
Old Jul 3, 2018 | 08:43 PM
Geoff's Avatar
Geoff
Originally Posted by yooperhog
LED Headlight?
The bike has a stock headlight. The only electrical mod is an amp and Screamin' Eagle spark plug wires. The wires are suppression type.
Loujr28
Jul 22, 2019 10:28 PM
Kokes58
Audio Systems
11
Oct 13, 2014 09:53 PM
Turk05
Audio Systems
21
Jul 4, 2013 06:59 AM
jpit11
Audio Systems
Apr 7, 2013 09:53 PM
KSGLIDEGUY
Audio Systems
Jan 25, 2012 09:23 AM
