One Last Idea on FM noise!
I've tried ferrites on all my power and speaker wires coming out of the SS amp, and FM is still bad. I have one big ferrite left.
Could putting the ferrite on the inbound power lead from the battery to the amp help?
I'm not sure which wire you mean when you say you put a core on the power wire "out of the amp." The amp has 4 types of wires:
1. Audio in (the RCA cables) or high power audio in (as when connecting to a stock HK head unit via the head unit's speaker wires). This might benefit somewhat from a ferrite.
2. Power (+12 and Ground). This is the primary source of noise and is the most likely to yield reduced noise if passed through a ferrite together.
3. Rem (which controls when the amp is on). Perhaps this is the one you already have a ferrite on? I put mine through a ferrite mostly because I had one laying around.
4. Speaker wires out. I didn't put a ferrite on these, but they may also benefit somewhat from it.
Thx!
Class D amp technology has been around for a while but only until recently has it really become a "mainstream" technology. Their size, weight, power output, no-heat design (low current draw), and price points make them great products. However that, just as anything else does, comes with a price and that's EMI radiation. Guys the problem is simple, we all know that; the solution however is not so simple for varying reasons and the main reason is FCC guidelines not being adhered to or enforced.
The bottom line is simple for those of you who just don't get it; Don't buy a Class D amp knowing it's inherent flaw of EMI and expect anything less from it. They're great products, they perform well, they're priced right for most, and they're pretty much bullet proof. If you like and want to retain FM reception, then look elsewhere for your amp requirements because Class D is not for you. I personally never paid attention to the FM part of it until long after I installed my first Class D amp. Why is that you ask? because I don't listen to FM, ever. Class D EMI does not have an effect on CB transmission, bluetooth transmission, Satellite transmission (GPS and audio), etc. It's only FM.
