Does a Ground Loop Isolator work?
Old Jun 18, 2017 | 07:16 PM
Budda109's Avatar
Budda109
Default Does a Ground Loop Isolator work?
I get Alternator noise with RPM's. If I use this Ground Loop Isolator will that help or eliminate the noise? Thanks
Old Jun 18, 2017 | 07:33 PM
BaggerAudioLab's Avatar
BaggerAudioLab
it will help, but I've found some also filter out low end frequencies. You are better off finding the issue vs. treating the symptom.
Old Jun 18, 2017 | 08:04 PM
Budda109's Avatar
Budda109
I have had this same system now going on the third year. About a week ago I started getting the whine with the RPM's. If the bike is not running it is crystal clear. While running it is still good but I can hear the whine. I have Biketronics Titans in front 6.5. 6.75 kickers in the rear. With Kenwood X998 and Power Acoustik A3000DB • 3000W Max Class D amp. Power and ground run from the battery to the AMP. Clean heavy lines. Same with the speaker line. I got my install advice from Haze and Gannicus. Why it worked for two years and now makes noise I am unclear. Only electrical add on was engine guard lights. LED. The power is pulled from the cig lighter which is where the amp trigger is but that should make no difference and it worked fine for 6 months. Any suggestions I am all ears. Thanks
Old Jun 18, 2017 | 09:06 PM
SgtMic's Avatar
SgtMic
Disconnect your leds and see if the problem persists.
Old Jun 27, 2017 | 06:20 PM
Budda109's Avatar
Budda109
Default Fixed it!
I bought an Isolator and two sets of high end 1 foot RCA cables. I hooked up everything and it was perfect. After wondering what frequencies I might loose from the isolator. I took it out and it still sounded perfect. I am guessing my cables were bad. Well I have an extra part but worth it. I am just glad it was so simple. Thanks for all the advice and comments.
Old Jun 28, 2017 | 12:21 AM
BaggerAudioLab
That was an easy fix!!! Yep, sometimes a better RCA is all you need. Can't say that's never happend to me.
Old Jul 3, 2018 | 07:52 AM
Geoff's Avatar
Geoff
I want to remove static from the speakers on my '99 Ultra. The bike uses a wiring harness for power and speaker connections. There are no RCA connectors. Any suggestions where I should connect a ground loop isolator?
Old Jul 3, 2018 | 08:03 AM
yooperhog's Avatar
yooperhog
did you change anything recently on your bike (electrical) that may have caused this to start happening?
hell i bought a cheap USB charger once and plugged it in to charge my phone and stereo went apeshit
Old Jul 3, 2018 | 11:48 AM
Geoff's Avatar
Geoff
Didn't change anything. Static was coming from the speakers when I bought the bike. Got it from an auction, so I don't know the history.
Old Jul 3, 2018 | 12:13 PM
yooperhog's Avatar
yooperhog
LED Headlight?
