Amp for just b3 horns?
Old Jul 3, 2017 | 07:21 PM
sponger's Avatar
sponger
Default Amp for just b3 horns?
If u guys were gonna run a dedicated amp for just the b3 horns, whuch would it be? Its gotta fit on the clutch side bt bracket. '15 sg.
Old Jul 3, 2017 | 07:28 PM
slyedog's Avatar
slyedog
Doesn't need to be much anything special. Only need 30-50 clean watts per side. 50 leaves bit of headroom. Alex has one he found iirc, or the little nvx amps would even work, just use the caps and keep the gains in check.
Old Jul 3, 2017 | 07:39 PM
sponger's Avatar
sponger
Do the caps come with the b3's? I know they did with the b2's
Old Jul 3, 2017 | 07:55 PM
Tailwind's Avatar
Tailwind
Some of these micros have gain only. Are the guys in the Horn Cult running horns in full/all pass or is a crossover essential?
T.
Old Jul 3, 2017 | 09:26 PM
slyedog's Avatar
slyedog
yes
T.
All amps would be full pass. Only a couple on the market that even have a cut high enough to run active. A xover is imperative. Don't want anything below 4k range coming out. They rate for lower but I didn't like it. Mine are currently ran of dsp with no caps cut around 4500 24db iirc.
Old Sep 5, 2017 | 05:16 AM
flcusat's Avatar
flcusat
I found this article the other day regarding using the caps as additional insurance when and active crossover are used. Makes sense to me.
http://www.audiofrog.com/community/t...ve-crossovers/
dabears1985
Audio Systems
Jun 23, 2019 08:49 PM
ew25950
Audio Systems
11
Apr 21, 2019 12:16 PM
bigh8840
Audio Systems
May 11, 2017 07:51 PM
Moto Mike
Audio Systems
43
Oct 13, 2016 01:46 PM
golfblues
May 3, 2008 05:34 PM
