Rca Voltage
Old Jul 14, 2017 | 09:08 AM
Delgado130's Avatar
Delgado130
Default Rca Voltage
Is there a significant gain in audio clarity going from 2.5v output to 4v output? I have a Kenwood kmr-m315bt. The Kenwood kmm-bt518hd looks exactly like the m315bt but with 4v. I am running a pn4.1000d connected to audiopipe horns, mmats 6.5`s, american bass 6.5`s in lowers and pioneer 6900 in lids. The gains are around halfway.
Old Jul 14, 2017 | 09:27 AM
SBates08's Avatar
SBates08
You won't be able to tell a noticeable difference at all. As long as your using good materials to hook everything up (good stranded wire and proper size for the amp, good RCA's, and good speaker wire) your in good shape.
Old Jul 14, 2017 | 01:23 PM
SOFTPETER's Avatar
SOFTPETER
2.5 to 4v a noticeable difference. 2.5 to 5 a huge difference.
Its worth it to me. Your amps will run cooler, and digital amps need all the signal they can get.
Old Jul 14, 2017 | 04:26 PM
matt76cmich's Avatar
matt76cmich
If you change the voltage output you will need to reset your gains on the amp(s)
Old Jul 14, 2017 | 08:22 PM
SBates08's Avatar
SBates08
Key word in this statement is "Amps". If you're running multiple amps then absolutely you want 4v or more from your HU. In an open environment, the difference in what you'll hear between a 2.5v HU and a 4 or 5v HU pushing only one amp is minimal at best. IMO it's not a big enough difference to rip out what you have unless you intend to add another amp later on.
Old Jul 15, 2017 | 10:02 AM
Delgado130's Avatar
Delgado130
I will be adding a pn4.520d and bridge it to the pioneers so I can have two channels from the pn4.1000d to run just the horns
Old Jul 15, 2017 | 11:20 AM
SOFTPETER's Avatar
SOFTPETER
Yep.. time to upgrade. You will love 4v vs 2.5v.
falconbrother
EVO
33
Aug 20, 2023 07:55 AM
SparkyD
Shovelhead
17
May 10, 2018 12:00 PM
Marks57
Audio Systems
21
May 8, 2015 12:02 PM
pehenley
Ironhead
Aug 30, 2013 08:19 PM
mp
Sep 6, 2007 09:07 PM
