Amp install question
I made a power harness from 10ga wire and an in line blade fuse holder, with marine crimped ring terminals on the battery side.
My question is what to do with the amp side. The B52 has what I imagine are "typical" set screw power inputs. So do you just strip, twist and insert the cables? Or is tinning them a good idea? I think I saw someone mention using banana connectors? Lastly, any loctite on the set screws?
I'm thinking straight cable probably makes the best contact, but since its effectively "outside" I am worried about oxidation.
Thanks
Kris
remote trigger harness
Amp and BT355
Power cable. Had some mesh left over from another project. Used a spade fuse holder I soldered and heat shrinked.
And the speakers
Wish me luck!
As soon as I'm done with work (company has great WFH benefits) I'll head down and get started. Looking forward to it!
Bracket, with alcohol wipe drying..
Amp velcroed down
Zip ties to finish it off.
Tank off, battery cable run, no problem. Took the opportunity to run my Power Vision cable up the channel as well, and cleaned up the Love Jugs fan power as well. Tank back on. Torqued everything back up. Moved on to the fairing.
Fairing off. Headlight off. I guess the hogtunes amp they show in their video is slimmer then the B52, cause there was no way it was fitting. I had to pull it off the bracket, install the bracket and then coax it in position. Thank God for the patch of Velcro they provided, cause if I used the 3M VHB tape i planned on, it wouldn't have been a good day.
Got everything installed, even reused the grommets around the speaker wires, by making a single cut and peeling them off the factory speaker cable. Switched accessory power on and - there was "Pigs" (a little Pink Floyd always brightens my day).
So I tidy'd everything up with some zip ties and put everything back together.
I realized I forgot the hogtunes grilles up in my apartment, so I cleaned up and headed upstairs. I actually thought I managed to complete a job without forgetting something and having to climb up to the 12th floor, but at the end, it wasn't to be. And by climb I mean take an elevator... At least it was only one time.
Anyway I drank about a gallon of Gatorade because the parking garage was about 972 degrees of unmoving air, and I was sweating my ***** off the entire time. Changed my shirt and went back down. Popped on the grilles and started her up. (Remember to reconnect the fuel supply line, or the bike no start...) I had every intention of going for a ride, but when I opened the garage door and voila! rain.
So i listened to some tunes in the horrible acoustics of a 60 car underground concrete parking garage, and came home.
All in all, its an enormous improvement over the factory garbage. I ballparked the sensitivity and I think its fine. I have to ride a bit and listen before I make a final call on that.
So, here it is: I know you're thinking "where are the photos?" Well, it was so damn hot down there, I'm basically an idiot and didn't take any because I just wanted to get it done. Besides, you all know what this stuff looks like anyway.
Summery:
Parts used
Cerwin Vega B52 amp
BikeTronoics BT355 Line level converter
Polk MM652 speakers
Hogtunes Amp bracket
6' 10 gauge power cable
generic speaker cable
monoprice premium interconnects
Observation:
A lot louder. A lot cleaner at high volume. A lot more detail and clarity. Don't know how else to describe it after only 5 min or so of listening, so I'll reserve my final report for when I have had saddle time.
Thanks to everyone who contributed valuable suggestions for this project. Much appreciated. Couldn't have done it without you!
