Lowers
Old Aug 10, 2017 | 12:53 PM
Brent Michael's Avatar
Brent Michael
Default Lowers
Tp speaker upgrade or add lowers?
Also, running the psc3004 hawg wired to HAT imagines in batwing.
If going with the lowers will the ebay pods work and some suggestions on which speakers to get. Thanks for the help
Old Aug 10, 2017 | 02:55 PM
BlackPearl#1's Avatar
BlackPearl#1
https://www.hdforums.com/forum/searc...rchid=40747010
Use this handy search feature that is located in the upper right corner. I recommend hitting advanced search and putting whatever you are looking for in the search box, then hit titles only then hit search. There are about 1 metric A$$ ton of fairly current lowers conversations. Hope this helps.
Kris
Old Aug 10, 2017 | 06:17 PM
Gannicus's Avatar
Gannicus
What Bike?
Just a couple notes:
1. That amp is only 4 ohm compatible. Can't run 4 ohm speakers in parallel.
2. It's only producing 75 watts x 4 to your hat speakers. Not nearly enough juice.
3. You're gonna need a bigger amp bro!!
Scooby1426
Audio Systems
May 17, 2019 07:00 PM
rblahetka
Audio Systems
19
Dec 9, 2017 10:31 PM
INSteelersFan
Audio Systems
Sep 25, 2014 11:08 AM
FFeric
Apr 4, 2011 08:04 PM
FFeric
Apr 25, 2008 05:56 AM
